Replacing drivebelt/Mitsubishi Galant GSR 1992 Model
How do I remove the old belt
  • Patrick McGee
    Patrick McGee May 11, 2010
    Try posting this under the cars section, as you posted this under graphics cards and only computer tech's will see this. Be sure to indicate your size engine in the new posting.
    Sergeant:
  • 233 Answers
You shold disable built in vga from bios or make the AGP port as your primary
Posted on Jul 07, 2008
1992 Mitsubishi Galant gsr 2000 Dohc replaced fuel pump ... won't start plenty of spark, getting fuel fuel to the rail but not into the pots....
It may not be getting enough pressure in the fuel rail could be a fault in the fuel pressure actuator or relay
Oct 10, 2016 | 1992 Mitsubishi Galant
My car's brain box is bad and i cannt find it in Abuja here in Nigeria
The can be found here in the US but not sure as far as shipping there and how to go about it. They seem to go for around $300 - $400 dollars depending on which one you have so you would need the numbers off the old one to be sure you recieved the correct one. Also there were like 5 different models of the Galant made during that time. The GS, GSR, GSX,LS and the VR-4 and would need to know what model you have. You can email me at csautomotivecars@att.net if you want me to look further into this for you. Have a great day.
Jun 03, 2011 | 1992 Mitsubishi Galant
What is the cost of replacing a water pump on a 1992 mitsubishi galant gsr?
Labor and part? It would probably be close or around 500. The water pump is on the timing belt. That is a pretty good little job. It might cost more then that.
Mar 03, 2011 | 1992 Mitsubishi Galant
How to replace water pump in a 1992 mitsubishi galant
All Mitsubishi cars pretty much hide the water pump under the timing belt. You should buy all new belts for the car and consider replacing the water pump at the same time.You will have to take off the power steering belt, the alternator belt, the upper belt cover, support the motor, take off the motor mount, jack up the right front corner of the car, take off the front right tire, take off the engine plastic under cover, line up the TDC timing mark, Take off the front wheel ,take off the plastic splash cover, using an air wrench take off the lower pulleys, take off the lower engine cover, observe the timing marks/arrows and highlight with paint (on the crankshaft,counter balancer shaft , and cam shaft),take off the timing belt, counter balancer belt if there is one, water pump belt, and now you can unbolt the water pump, scrape the gasket, and replace it. Now the good news, if you have tools,a compressor, an air gun(for lower pulley bolt), patience , and four to eight hours to kill, you can actually do it your self.
Nov 12, 2010 | 1992 Mitsubishi Galant
I have a 1991 Mistubishi Galant and it needs an alternator what information would I need to know about the motor in order to get the alternator? I don't know any of the information and hoping you could...
You will need to know the motor size or number of cylinders. I believe it only came with a 2.0 liter, but I may be mistaken. They may want to know if it is automatic or standard transmission and if it has A/C or not. They will ask what model Galant it is also, base model, GS, GSR, etc.
Sep 28, 2010 | 1991 Mitsubishi Galant
How to adadjust timing on my ENGINES:- 4G64 EXT W75C
There is no "outside" adjustment.
This involves getting inside - to the Timing Belt and checking the Timing Marks and Belt.
Click on the following free direct Link. It has the Timing: Belt and Mark Diagrams for your 1997 Mitsubishi Galant 2.4L. Plus additional Instructional and Directional Diagrams.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1997/make/mitsubishi/model/galant/1997_mitsubishi_galant_timing_belt_diagram_marks.htm
You may also Click on the following free direct Link for Diagrams on the access to the Timing Belt, in the removal of the Serpentine/Drive Belts.
http://www.2carpros.com/car_repair_information/year/1997/make/mitsubishi/model/galant/1997_mitsubishi_galant_drive_belt_routing_diagram.htm
Apr 01, 2010 | 1997 Mitsubishi Galant
How do you change the alternater belt on a 2001 Galant?
My apologies for the delayed response. I am going back to answer unanswered questions.
1. Yes, you have to take the other belt off to take this belt off.
2. I use a wire brush to get melted rubber out of the grooves on pulleys with grooves. I use a wire brush then sand paper to remove melted rubber of smooth pulleys.
3. You should always replace both belts instead of just one.
CLICK on the following LINK. I beleive it has the Diagrams for your Belts that you will need.
http://www.2carpros.com/car_repair_information/year/2001/make/mitsubishi/model/galant/2001_mitsubishi_galant_drive_belt_routing_diagram.htm
If you would: Before Clicking let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my sincerest apologies...
Thanks!
Jan 13, 2010 | 2001 Mitsubishi Galant
Pcv valve
unplug the old one and put the net on in it's place.  Look for a part that looks just like the old one.
Mar 11, 2009 | 1992 Mitsubishi Galant
Location ecu on 1988 mitsubishi galant. need codes
on my 90 galant gsr it is located behind the dash on the passenger side, remove glove box and you should see it. absolute pain in the *** to access
Mar 10, 2009 | 1989 Mitsubishi Galant
Diagram for serpentine belt on a mitsubishi galant es
My sincere apologies for the severely delayed response.
I am going back to answer - unanswered questions. I have only been on this site for the past 4-months. Questions Posted have exploded (+55%) since joining.
I do not know if you still need this information, but I am answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Thanks.
http://www.2carpros.com/car_repair_information/year/2002/make/mitsubishi/model/galant/2002_mitsubishi_galant_drive_belt_routing_diagram.htm
Jul 03, 2008 | 2002 Mitsubishi Galant
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
