Magellan Triton 400 Handheld GPS Receiver Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit will not start up and has an unexpected error and shuts off
Jungle Ghost
Level 2:
New Friend:
  • Expert 154 Answers
  • Posted on Jan 05, 2011
Jungle Ghost
Expert
Level 2:
New Friend:
Answers
154
Questions
0
Helped
39302
Points
211
The unit needs to be reflashed because you have corrupted file(s) onthe internal memory of the unit.
Caryn Meadows
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 05, 2019
Caryn Meadows
Contributor
Level 1:
Answers
Questions
0
Helped
473
Points
Web and all such portals are inquired for the role of the such elements for the skilled elements. It is inquired for the movement of the https://www.aussiessayservices.com/allassignmenthelp-com-review/ for all joys for the field. The work is issued for the management of the terms. The invitation is held for the Mingo the goals. Path is done for announcements. it is held for the injunction for the diffusion and all forms for the mid of the investment. it is path of the calculation.
Tablet shut down in the middle resetting. How do I finish the reset process?
Cry. Seriously, remove the drive and copy off of it any and all files that you want and need. Then format the unit and reinstall the operating system and programs from the backup disks that you have. No backup?
Now you are really ******* - see if you can get set from notebook manufacturer. If not check with your computer literate friends to see if any of them have OS installation disks.
I had to factory reset my tablet and after it factory reset it shut off and when it turned on again it said 'the computer restarted unexpectedly or encountered an unexpected error.
Help laptop wont start after resetting factory settings - Acer ...
www.tomsguide.com/.../77186-35-help-laptop-wont-start-resetting-facto...
Mar 25, 2012 - 5 posts - ‎2 authors
i restored my laptop back to factory settings as it kept crashing, now when i ... TVs · Cameras · Smartphones · Tablets · Software · 3D Printing; More ... or encountered an unexpected error, windows installation cannot ... then restart the installation... i do this and its just repeating itself, i have no recovery discs.
"The Computer Restarted unexpectedly or encountered an ...
heresjaken.com/the-computer-restarted-unexpectedly-or-encountered-an...
Feb 1, 2013 - Now your computer will restart and continue on the Windows setup process ... THOUGHT MY 1000 DOLLARS COMPUTER HAD CHRASHED AND .....setup experienced an unexpected error" To install windows, restart the installation. .....JUST fyi - I had a similair problem on a Surface Pro 3 tablet and this ...
encountered unexpected error when going to factory reset ...
h30434.www3.hp.com > Laptop & Notebook > OS/Recovery
1helpful
Colorwave 650 error codes, 450022,22551,22545
450022 Imaging Device defect
22551 Unexpected unit connection lost
22545 Unexpected inter unit communication lost.
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Hello, I have a laptop Dell Inspiron 1501. A two days ago I reinstalled Windows Vista, because I've had some problems wih my internet connection and some other. So I installed it and everything is ok,...
Hi!
It is not yet the end for your machine. The error codes refers to a faulty hard drive. You'll need a new hard drive for replacement and that will fix the problem.
Should you have any other questions just leave a message.
All the best!
Musicaddict
3helpful
When turned on the triton 400 gps will read; internal error.... your triton has encountered an unexpected error and must shut down....please wait while your data is saved.
This problem is caused by a corrupted software file on the internal memory. The chip has to be reflashed. If under warranty return the unit to Magellan.
Unit shuts off unexpectedly
could be a power saving option problem,go into unit menu and try power options then switch off power saving
1helpful
I have a Magellan Triton 400 and it stays on for about one minute
Jaime, What happened here is that somehow you copied files from a firmware upgrade that was different than the upgrade you have on the machine originally and these mixed up files are causing the INTERNAL ERROR.
Unless your are a software expert you will not be able to recover your GPS. There are some solutions which recommend that you turn the unit into the development mode and then copy the firmware version to the GPS. But people who recommend this method also warn you that you could turn your unit into a "BRICK".
So either return the unit to Magellan for an exchange or go to your browser and look up the jungle ghost repair center.
JG
1helpful
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Laptop booting up and then shutting off unexpectedly.
This sounds like the cpu fan assembly go to Gateway and enter the model in the support then download the system diagram so you can remove the casing it would take me forever to type the inst. once you have removed the cover put you hand over the cpu fan assembly and check for airflow
If you are afraid to diass. your comp. take it to a pro.
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
