Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Freezer repair I have a kenmore coldspot 106.52564100 the freezer stops working, but the fridge still works. I turn the entire unit off for a few minutes and then back on and the freezer works again for about a day. then it happens over again and I go through the cycle over and over again for a couple of weeks now. What can I do
  • rlmarkin Jul 06, 2008
    I cleaned the coils real good last week trying to solve the problem. I took the bottom covers off front and back and cleaned everything under the fridge.
    ok i just read the last post. I dont know what you are suppose to be doing to help me, but you just gave me a long list of things to just start checking. If i just wanted to start checking everything i could do that by myself. I figure I would get to the solution finaly. I was looking more for specific help not just start going through everything?
    Genius:
  • 1,665 Answers
The food in the refrigerator freezes This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
http://www.repairclinic.com/0088_4_1.asp
Posted on Jul 06, 2008
  • 1,512 Answers
Hi
Sounds like a faulty compressor start circuit, or thermostat letting you down. Time to get a fridgy out to have a look at it. There is not alot that can be done about these things by the layman. Good luck, thanks for using FixYa
robotek
    Genius:
  • 3,422 Answers
HI,
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Posted on Jul 05, 2008
  • 58 Answers
Maybe clean the coils on the back?
2 Suggested Answers
  • 572 Answers
SOURCE: Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Posted on Feb 08, 2010
Kenmore coldspot, freezer frosted up then auto defrost and both freezer and fridge stopped cooling. unplugged and defrosted and now freezer works but not fridge. vacummed coils already. 3 yrs old.
Check the freezer fan motor.
Is it working>
If not,replace it.
Also you must replace the defective defrost parts.
Timer......heater.....thermostat.
May 08, 2011 | Refrigerators
Feb 08, 2010 | Refrigerators
Kenmore fridge not cooling
try www.partselect.com
would help if you had a part number
Sep 30, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot EM5119829. The Freezer works
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
or..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Kenmore coldspot 106.54563300 is not cooling. First the freezer stopped cooling then the fridge stopped. The fan is still working. Pulled fridge out, compressor was very hot. Is this a relay problem? If...
Not good news, it sounds like a compressor problem. Vacuum clean everthing you can safely get to in order to make it eaiser for the repair guy, (hopefully to save money). How old is the fridge?
Jun 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Freezer quit however fridge appears to be cooling...
if there is a fan in the freezer; in that is not working then yes OR the thermostat has gone. But the unit only has one compressor and if the fridge is working it is normally a good sign.
If you where really concerned you could call a domestic refrig tech they could fix it.
Hope that this helps
Jan 11, 2009 | Kenmore 50522 / 50524 Side by Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
132 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
