Question about Asrock K7VT6 (K7VT6 RAID) Motherboard
Need a diagram of the board to put the pins in the right slots.
Re building spare comp and have taken the k7 out of my old machine but lost the diagram to put in the pins. hope you can help.
  • 2,794 Answers
I need instructions on replacing the thread take up spring Juki DDL 8700
contact a juki dealer to see if they can give instructions
Jan 31, 2012 | Juki DDL-8700
K so like I have an old K7 PRO VER:1 Motherboard its an AMD and I want to add some ports to it its got some other numbers on it too like N1996 it also says MICRO-STAR in really small letters and it has 3...
I am unfamiliar with what you mean by ports?
But, you cannot add more slots to your motherboard. The black ones are called ISA slots and the oldest kind, i doubt you would be able to find cards for that slot anymore. The brown one at the top is the AGP slot and it can only be used for certain types of video cards. I don't believe these are sold anymore either, but you might be able to find a used one.
If you are looking at added more devices to you computer, you will probably have to use something that connects using USB.
May 04, 2011 | Computers & Internet
Plugged old an older HD into my custom pc and now no video appears on screen.? I was trying to help my wife retrieve old photos from her ancient 800mhz hp computer so i took the hd out of her pc and put...
What you need to do is put the old HD in as a spare drive, not replace the one in the computer. Each drive can be either a Master or Slave. The pin settings are usually written on the drive. Once the computer boots to the regular drive, the OS will recongize the spare drive and give you the ability to open it and get your photos off of it. Make sure that when you start the computer that the cables are seated correctly on the board. The Master drive once you set the pin settings on the drive should be plugged into the Primary IDE controller, which is the plug closest to the edge of the board. Then the secondary drive, or slave once you set the pin settings, should go in the secondary IDE controller, which is the one right behind the primary. Then give it a try. Also, the older HD, what is the brand and model, maybe it's not compatible with the Intel board?
Thanks Mark
May 09, 2010 | Intel D875PBZ Motherboard
How to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service:
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
Titan-SCR2 N-120, water heater, need schematics
I have taken pictures and produced a wiring diagram for this model
Jan 23, 2009 | Water Heaters
Installation of one touch mini 4
hello, if you are adding an extra hard drive for space make sure to change the teeny jumper to the proper pins next to the connection slots on the hard drive. the jumper makes your hard drive work as a slave (extra drive) or a master (main drive). if you have a main drive allready on your comp and you dont switch the jumper the slave position the computer will not recognize it becuase of the new hard drives jumper being in the master position or pin connector.
if your installing it as a 2nd master drive you need to use your extra hard drive slot on the mother board for this to work as a secound master then you need the jumper in the master pin slot. there is a small diagram on to the hard drive info label it looks like pins and it shows you where to locate or place the jumper for either master or slave.
for a slave drive once you have placed the jumper properly then you can instal it on the same cable with the main. look at the cable it will have a main and a slave small label printon the connector or if you prefer you can use the 2nd hard drive cable on the secound slot on the mother board turn on your comp if you are going for a extra hard drive the comp should recognize it if the jumper is properly placed. when your comp is running you can check by going into (computer) and it should be there as a new drive letter
after this you may need to format the drive for use. you right click on the hard drive letter and choose format drive
hope this helps good luck with your upgrade.
Dec 10, 2008 | Maxtor Hard Drive
Front panel connections
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Nov 30, 2008 | PC Chips M848ALU Motherboard
Hi bad, there are 184-pins per slot if the board uses 184-pin memory. These pins have wafer wiring so close to every pin, removing just one without damaging the board would be impossible. You would also need to remove another 184-pin slot off another board to replace your's. Memory slots are not found just anywhere. Fact, I never heard of anyone trying this. You would be the first! If you do try it & you melt just 1 wafer, kiss the board goodbye. Don't listen to me. If you have steady hands, a high power magnifier an old board to remove its slot, go for it!
Worst case? You'll need to buy another board.
God Bless You!
May 28, 2008 | Intel Motherboard
Soyo dragon dip switch settings
here is the pdf with your user manual from the board.
the pci indeed is the slot for the modem and for the sound card,also.
the pci are slots near the agp slot..shorter than the agp.they are equivalent so you can put the modem and the sound card and to interchange the place if you want.
I think youll find more usefull infos in the manual anyway.
good luck
Feb 06, 2008 | Soyo KT600 Dragon Plus Motherboard
Asrock K7VT6 (K7VT6 RAID) Motherboard Logo
161 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
