FixYa.com
Tags:
RCA P52926 52 in. Rear Projection Television
PHILLIPS 60PP9202/17F (by 2 users)
posted by DAREICHE on Jul 05, 2008
tV WILL NOT TURN ON WITH REMOTE ON BY PRESSING THE ON BUTTON...
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by dixie46, posted on Jul 16, 2008
The tv won't turn on. When I press the button on the front of the tv, it makes a popping noise about 3 times.
Solution #1
posted on Aug 13, 2008
Not Rated (0)
yambo
Rank:Wiz Wiz
Rating: 82%, 25 votes
Possible leak coolant projection. Or SSM board ( small singnal board) located at the let tuner board ( vertical position). Maybe need be replaced convergence IC's. stk392-110 and some resistors around 6.8 Ohms 2 watts
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
rca tv no picture
rca projection tv model... Answer This...
RCa P52926 52inch
We turned our Tv off last night... Answer This...
RCA D52W19 screen flashing and...
Problem first started with the... Answer This...
2001 52" RCA Rear...
The television worked fine then... Answer This...
52" RCA Entertainment...
Hi, I am trying to find out... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
