Question about Microsoft Xbox 360 Console
Got sound, but no picture for my XB360
I've tried the cable swap, tried different inputs on my tv, but alas, still no picture. I have audio, but the video seems fried. Any advice?
  • joshpeter Jul 05, 2008
    my xbox 360 suddenly cut out the picture and only has audio and changing all the cables and even the tv makes no difference you can hear it running but no picture still
    Scholar:
  • 29 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio but no video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem.
Posted on Mar 14, 2009
    Problem Solver:
  • 7 Answers
Well if there is no red light on your xbox 360 all is fine its the video cord i suggess you buy a new one thanks nick
Posted on Jul 05, 2008
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
Haier tn201auv have picture but no sound
Check the interconnection cables for firmness. Check the audio inter connection cable for internal conductor break. Check with a new cable.
Jun 09, 2012 | Haier TN201AUV 20" TV
I have an onn 42 inck flatscreen tv and since last night have lost all colour on screen,,,tried cable and scart all seem ok,,any ideas
Hi.
If the problem happens using different input and devices, then it is either the terminal circuit (input/output connectors) or the processing unit in main board. The terminals are unlikely the culprit if problem concerns different inputs.
I imagine that the picture is not properly B&W (gray-shades) but some kind of reddish, bluish or greenish picture as the LCD will process picture using RGB (red green blue) channels instead of CYMK (cyan yellow magenta black) like CRT TVs.
Test the TV using an external aerial. You will notice if the channels have the wrong color even from static.
Use different inputs, different cables and different devices. beware of SCART cables, the SCART contacts are very easy to break. A defective cable will loose picture. Better testing using AV cables and component cables. AV cables are red/white for sound and yellow for video. If the two-wired yellow cable does not work, then the TV is faulty.
Other test can be done using component cables. Component cables send the three red-green-blue signals on different cables, hence testing is simple. Test swapping cables and see if TV tone stays the same if color tone changes the problem were the cables. Test also using at least two different devices (e.g. one DVD player and one TV receiver or a playstation).
If you find that the TV is defective call the manufacturer at the number listed on manual. If the problem is that one or more RGB channels do not work the TV main controller board must be replaced.
Regards.
Ginko
Sep 13, 2011 | Televison & Video
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
My 22 lcd gives good picture but no sound.I've tried connecting an externel head phone but i don't hear any sound.
you're best bet is, depending on your TV's input/output, is to run your video components directly to TV via HDMI, component, etc., of course component requires additional sound cables, then run your sound out from TV via, best, digital optical, to reciever. You use the TV's menu to choose what you watch and, only have the one audio out. Scan your recievers menu to make sure you've got the right channel to listen to.
Jun 28, 2011 | Audio Players & Recorders
Well i plug in the wii and i took it out but when i took it out i guess i pulled out the wrong plugs and now the tv won't show a picture or play audio
It sounds like you've disconnected your wii and are now trying to watch tv on the same input as your wii once was. You need to check your television for a button labelled "input" or on older model TV's "tv/vcr".
A trick you can use is simple: find the remote or use the channel up/down buttons on the television. Change the channel. You should now be watching your cable!
A side note: If someone else set up your television, they may have used a different input for a cable/satellite box. In this case you would just need to press "input" until something comes up on the screen.
May 03, 2011 | Sanyo DP46849 46 in. HDTV
Different sound to picture
When connecting VCR to TV. Verify all connections. First if the connection is with coaxial cable make sure you signal from outside is screwed to the cable input on VCR. Then the VCR/TV output has the cable running to TV input. If hooking up with RCA cables , which is the yellow, red, and white cables. Hook one side up to VCR output. Yellow for Video, while red/white to audio output matching the colors. The same is done to the Television input. yellow for video, red/white for audio. Do a test recording. Use a blank tape, not one already recorded on. Record about 5 minutes Stop recording , rewind and playback. You should see the difference.
Oct 13, 2008 | Televison & Video
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
No sound when using coax...
Do you use AV inputs for your Cable box? If so, try swapping the audio inputs in the TV, that is, interchange the AV inputs for your DVD and cable box. If sound is audible in a different input, then the Audio input (for Cable) on your TV is faulty. One simple suggestion, Why don't you route your Cable signal through the Tuner of your VCR?
Aug 08, 2006 | Zenith C19A21D 19" TV
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
