Question about JVC RX-6030V Receiver
No sound in FM radio
Works fine..then when i go to FM.........no sound.......the "auto mute" sign comes on........I push "mute" on the hand control.......but it doesn't turn off the "auto mute"
I had same problom and fixed by connecting an antenna to fm port
Posted on Jan 07, 2009
Jvc car radio won't mute on incoming calls
I think the only hope you may have is the radio has an auto signal select in the menu somewhere. You can't use the mute wire as that will mute the AUX as well.
Dec 08, 2013 | JVC Ks-bta100 Bluetooth Adapter For Select...
Receiver comes on but have no sound tried the solution; but it still didn't work. What I am seeing is, in the upper left hand corner of the window in small writing says "mute auto" which is...
Mute Auto is for FM only. It mutes interstation hiss while tuning. Look for some other indicator that might reveal why the signal path is failing. Tape?
Have you tried the basics? Speaker test? FM only?
Sep 01, 2011 | JVC RX-554V Receiver
When i put the fm radio it display auto muting and doesnt have sound, this only happens with the radio because the dvd sounds ok
"Auto Muting" in the context of FM means the output will be muted if the signal is so weak it would result in mostly noise anyway. Interstation radio noise can be annoying and dangerous at high volumes.
Aug 14, 2011 | JVC TH-M303 System
I have a Bose Lifestyle v20 home theater system and whenever I use the radio ( FM/AM ), no sound/music comes out. The rest are fine, but only the FM/AM ones dont work. It used to, but now its gone.
I hope you checked if the antenna wire is connected before reporting this defect.
All modern radios have automatic muting. No sound will come out unless the receiver gets enough signal strength to give you an undistorted sound, so if your antenna wire is disconnected you will get no sound.
Jun 15, 2011 | Bose Lifestyle V20 System - black Theater...
FM radio on Sansa Clip does not work
Have you muted the radio by mistake.If you have there will be a square symbol under the FM sign.Press the top of the ring.
Jun 04, 2010 | SanDisk Sansa Clip MP3 Player
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
Everything works fine on the unit no problem until
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
No Sound for AM/FM Radio
Ensure that the antenna is still attached. It will auto-mute if no signal is attainable.
Sep 12, 2007 | Onkyo DR-C500 Multi-disc DVD Player
JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Dec 03, 2006 | JVC RX-618V Receiver
JVC RX-6030V Receiver Logo
720 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
