Question about Kenmore 25812 / 25813 Progressive Bagged Canister Vacuum
Burning smell from motor...what needs replaced?
There's a burning smell coming from the canister, and the motor's speed sometimes drops. I'd like to buy a replacement part and fix it, but I'm not sure what went bad. Brushes, maybe?
    President:
  • 1,673 Answers
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Posted on Sep 01, 2008
Burning smell
The response by Lynnette is in reference to the power nozzle....if you are having this issue with the main unit, then it could be the armature is starting to go bad. Have your Rainbow in front of you and give us a call. We can walk you through some steps to narrow it down.
www.rainvac.com
800-523-0510
Apr 09, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Work well but smell like a burning belt
If it smells like burning rubber, the belt is probably worn and slipping. If it's another burning smell, your motor windings are probably shorting and will burn out soon
Oct 12, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Check your filter and also check that nothing got pulled into the motor...otherwise the motor is burning up and will need to be replaced... probably cheaper to replace the whole vacuum..
heatman101
Aug 27, 2010 | Numatic HVR200P Bagged Canister Vacuum
When I turn the vacuum on it sounds really loud, louder than usual, and after a few minutes it smells like burning rubber around the canister. The vacuum is still sucking.
The armature is probably missing a plate and the motor is about ready to burn up, but check the filter and screen on the bottom of the motor first. The screen can be checked by removing the filter and looking up at the motor from below. Clean if necessary by removing the motor. Unplug the unit first. If the motor sounds rough and smells like something electrical burning. It's going to need to be replaced. Check your model # and order a replacement. Pretty easy to install if you get the right motor. Get the foam gasket for under the motor if your replacing a three stage motor.
Jun 06, 2010 | Electrolux Centralux Vacuum
Miele Vacuum Cleaner - burning smell / motor won't stay on
check brush the belt may have popped off and is binding or brush is binding clean brush of any debris thread/hair wrapped binding brush and check and or replace belt
Mar 24, 2010 | Miele S318 Bagged Canister Vacuum
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
Motor slows down and makes burning smell
If the noise is coming from the canister motor, you probably have bad motor bushings. I had the same problem, replaced the motor and all was fine - only for one year. The problem is back and is due to the fact the motor is very high speed (to get good suction) and should be made with bearings, not bushings. I will not be repairing a second time as a $70 motor annually is a bit pricey, and yes it will get VERY hot. I will buy a new vacuum - not another Kenmore.
May 25, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Burning smell kenmore canister
Had a burning smell coming from the vacuum. Opened it up and noticed sparks in the motor area. Ordered a new motor from Sears and replaced it. Works great now.
Mar 04, 2009 | Kenmore Vacuums
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Kenmore 25812 / 25813 Progressive Bagged Canister Vacuum Logo
228 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
