Making free calls to skype contacts
When i try to contact another skype contact i am told that the call has failed
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Hi desmondpark - when you open the skype box are you able to make a test call ok? Are you using the country code?
If you are actually calling their computer it is free. So check the number if it is a cell phone # it is not free.
Posted on Jul 08, 2008
No webcam for skype
Click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam.
Click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver W7.
Click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question mark?
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
It might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you
want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash andQuicktimesoftware are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c- Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
Also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
Open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call.
Make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment.
Click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings.
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
Select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
Not Showing the Other Person
Online Status
When one of your Skype contacts is not online, they will not show up in your list of available contacts.
It is possible to hold a conversation with someone who is not on your friend list, however; if you are trying to talk to someone you have previously chatted with but does not show up on your list of contacts, check to make sure that you have added the person.
All of your added contacts will show up on your list; the ones who are offline will have a grayed-out Skype icon and the contacts who are online will have a green icon next to their name.
If you cannot see the person's name, you may need to search for them and create a new contact.
Availability
Skype users have the option to change their availability when they are signed into the program. The status availability options are: offline, online, SkypeMe!, invisible, away, not available and do not disturb.
If the person you want to talk to is signed in but has selected the "offline" or "invisible" availability, you will not see them as online.
For the name to show up on your list of online contacts, the person must change their availability.
Blocked
If you cannot see a person that you have already added to your list, there is a chance that the person has blocked you.
When a Skype user chooses to block you, you will not be able to see anything about availability.
Even if the user is online and accepting messages, you will not be able to see the status and messages will remain undelivered.
Video
If you are trying to hold a video chat with a Skype contact but cannot see the person, there are several possible reasons.
If either of your Internet connections are too slow to support streaming video, the video will not come through.
If you have been chatting by text and switch to video, the other person will need to enable the video stream before you can see them.
Other culprits can include out-of-date webcam drivers, unplugged webcams or another video-enabled application running at the same time.
Share Both Screens in Skype
Sign in to Skype and right-click on the contact you want to share screens with.
Click "Call" to place a call to the user. When he answers, the Skype call toolbar will appear beneath his avatar.
Click the double square icon on the toolbar.
This is the share button.
Click "Show Entire Screen." Your screen is now visible.
Ask the other person to click on the double square icon and then "Show Entire Screen."
Sep 10, 2013 | Acer Aspire 5600U all-in-one desktop
Webcam not working skype
Online Status
Availability
Blocked
Video
Aug 09, 2013 | Lenovo IdeaPad Computers & Internet
My skype not working
Online Status
Availability
Blocked
Video
May 22, 2013 | Computers & Internet
Im anew account from skype
Installation
Download Skype from the Skype website (see Resources), choosing to "Install" and "Run" the program when prompted by your PC.
Double-click the Skype icon on your desktop to open Skype. A small window, titled "Welcome to Skype" will pop up, prompting you to type in your Skype name and password--if you don't have one, click on the option under the "Skype Name" input form titled "Don't Have a Skype Name?"
Input your details into the "Create a New Skype Account" window that pops up. It asks for your full name and email, and you will have to create a Skype name and password. Click "I Agree-Create Account" once you are done and have perused the Skype license agreement. The Skype interface will come up, from where you can make calls and video chat--you will be logged in under the Skype name you just created.
Using Skype
Find contacts--friends or family also on Skype--by clicking on the upper left-hand menu item in the Skype interface named "Contacts." Click on "New Contact" and input your friend's full name, email or Skype name and click "Find." Alternatively, click "Import Contacts" from the "Contacts" menu to import contacts from a number of various programs, such as existing Facebook, Hotmail and AOL accounts.
Contact another Skype user on their computer by clicking on his name in the "Contacts" panel on the left side of the Skype interface. This will bring up a number of options in the right-hand panel of the Skype interface. Click on the green button that says "Call" to make a voice call to this person's Skype account. Click on the green button that says "Video Call" to make a video call to this person's Skype account. Type an instant message into the text box at the bottom of the Skype interface to start an IM conversation with this person.
Call a land line or cell phone from Skype by clicking on the "Call Phones" button on the bottom left of the left-side panel of the Skype interface. This will bring up a large number pad in the right-hand panel of the interface, but you need Skype Credit in order to call.
Click on the "Buy Skype Credit" in the small box on the far right of the right-hand Skype interface panel. This takes you to a secure page. Follow the prompts to enter your billing address and credit card number, and your Skype Credit will be loaded. Go back to the "Call Phones" page and enter the phone number you wish to call, then press the large green button that says "Call."
Jan 03, 2012 | Skype IM
I have a skype account but when itry to use it for calls within Canada I am told I do not have enough credit in my account to make the call. thought skype was free?
Skype is free to call and chat with other Skype users through Skype. You need to buy Skype credits in order to call landlines or mobile phones from Skype.
Sep 28, 2011 | Skype IM
I want to use Skype IM but all I can get is a stupid ad for selling me phone time.
if you are probably trying to cal your friends out of skype, so you need skype credit to call outside. Just in case you add your friends(who are on skype too) to skype, you can call for free.
You can add contact following these steps:
In the menu bar, click Contacts > Add a Contact.
Enter the Email, Phone number, Full name or skype name(if you already know your friend's name on skype) of the person you want to add. If the Skype account of the person you wish to add is displayed, click Add below the contact.
If more than one Skype account matches your search:
Click View for a list of matching Skype accounts and click Add contact next to the one you wish to add. Before the contact can be added, you must send a contact request to that person. Enter some text to introduce yourself and click Send request. The contact will be added to your contact list, but will appear offline until they accept your request. Once the person agrees to your request, they will be added to your Contact list. Then you can make free calls and free video calls to that person.
Hope this helps,
Lucas
Jul 11, 2011 | Skype IM
Canton use skype
Reinstall Skype. It should take about 3 or 4 minutes.
May 15, 2011 | Skype IM
I have installed skype but I am failing to use it,can you help
Have a look on this video on how to use Skype, you may want to skip the first part about installation:
Jan 27, 2011 | Skype IM
I dont really know
you should have a messenger program operating on your computer either skype,yahoo messenger to use a webcam when you make a contact to someone using the same you will have the options
make a video call or call or you can simply type a sms message
if you decide to download skype
If you are using skype
open skype go to tools from the drop down list select options scroll to audio settings
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it
Jan 27, 2011 | Computers & Internet
I have just downloaded Skype and want to know how to make a call with it?
Computer to computer calls are made by adding the contacts from your email lists or by adding an email name and asking Skype to locate them. If the user has Skype, you can call their PC. The other user must have Skype.
You can ask Skype to search your address book for Skype users to make this process go smoother.
If you are trying to make a PC to telephone call, you have to add money to your account. This is called buying credit. Land calls are 2.1 cents per minute. PC to PC calls are free.
You can dial any number using your keypad.
You must have a microphone and speakers to make a call to a land phone or other PC.
If you have a camera on your PC, you can make video calls from PC to PC. If the other person has a camera, you can see each other.
The button that says make calls is clicked and you follow the instructions on the screen. The red button is to hang up the call.
May 10, 2010 | Dell Latitude D600 Notebook
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
