FixYa.com
Tags:
JVC KS-AX6300 Car Audio Amplifier
Amp power
By Kim1 - usenet poster
Should I run the amplifier powered from the receiver or from the battery?
Forgive me, I am new to this.
Receiver is Kenwood 416S
Amp is JVC KS-AX6300
Thanks for your help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
18" !!! Yikes as close to the battery as possible, the more wire unprotected
the bigger chance of smok'n the ride.
"This message has been smiley-captioned for the humor-impaired."
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
Make sure the fins are vertical or the amp wont cool right.
Solution #3
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rating: 0%, 0 votes
That's the simple cure... the amps cooling works by convection. If you have
the fins horizontal then the heat just rises into another fin.
Solution #4
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
my amp is mounted with fins horizontal and it overheats alot in the summer,
could this be why?! should i simply just twist the mother fucker around?!
after all sorts of fan-building, driving really fast with windows down, and
component cooler from radioshack, all i had to do was turn it to make the
fins go up and down?? i'm skeptical though if this will actually work,
before i break out my toolbox .. does it really work??
Solution #5
Not Rated (0)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
To take advantage of convection cooling yes although since a lot of amps are
usually mounted flat that's not going to work is it.
SOja
Solution #6
Not Rated (0)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
It'll work just fine!
Solution #7
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
Don't mount your amp directly in contact with the metal surface of the
rear wall of your cab. Install a piece of plywood or MDF to the metal
surface of the wall then install the amplifier directly to the wood
panel. You can paint or apply vinyl or carpet to it if you want it to
look nicer than bare wood.
The reason for not affixing the amplifier to the wall directly is that
you don't want to run the possibility that some amps reference
internal grounds to the amplifier chassis. This could cause a ground
loop and make for a noisy installation. Also mounting to a board
ensures you are installing the amp on a smooth flat surface not one
where their may be undulations in the metal framing that could cause
some flexing or torsion on the amplifier when it's secured....
On Wed, 3 Oct 2001 15:06:19 -0500, "Twawsi" <twaw @bellsouth.net>
wrote:
Stephen "Canuck" Narayan
Ampman Audio Sales/Technical Associate | step @ampmanaudio.com
ICQ UIN# 23618874  | IRC Steve-N on EFnet | snara @sympatico.ca
TeamAMP Member #034 | http://www.teamamp.com
teamROCS Member #068 | http://www.teamrocs.com
Solution #8
Not Rated (0)
man1
man1 - usenet poster
Rating: 0%, 0 votes
Very possible.  You just have to make sure what is behind the wall.  You do
not want to puncture anything important.  The screws should be short enough
that they will not go all the way thru.  Also, check mounting the amp with
the fins straight up and down.  I am not sure if this matters but, I have
heard that heat can be a problem if not mounted properly.  Someone here
would know for sure.
Douglas
Solution #9
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
It must be powered from the battery, but don't forget to connect the REM
(Remote
Turn-On Switch) so that the amp turns on/off when you turn the radio on/off.
A.
Solution #10
Not Rated (0)
Ranny
Ranny - usenet poster
Rating: 0%, 0 votes
You run your main power from the battery and the remote turn on from the
reciever. contact me at jef @fuels.homeip.net if you have any question and
I will be glad to help you personally.
Jeff Hardy
BassHeadache Audio
Amherstburg, Ontario
Solution #11
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
Thanks I really appreciate your help
One last question,  Can I mount my Amp on the back wall of the cab of my PU
or do I have to worry about drilling through the wall?
Thanks again
Solution #12
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
We all have to start somewhere. Straight from the battery with a fuse about
18" from the battery would be best.
Douglas
Solution #13
Not Rated (0)
Bray
Rating: 0%, 0 votes
battery!
-ZtH01
Can you Help with these Car Amplifiers problems?
Car Amplifiers
car amplifiers
i have a Jeep Grand Cherokee... Answer This...
Car Amplifiers
yjhrt
Car Amplifiers
schematic for washburn pg 65 c
need schematic Answer This...
Car Amplifiers
NASHVILLE DAB35
CONECTARE Answer This...
Car Amplifiers
code for kenwood cd player
I just bought this car... Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
