Question about Maxent MX-42V1 42 in. Plasma Television
Swap or return
I don't have the manual how do you return to the previous channel
Model # WF20L6 symphonic
Posted on Jul 05, 2008
Vox vth120 valvetronix No sound from left speaker output
Try swapping the Left and Right speakers with the following procedure, observing correct polarity of wires:
[i] Label both speaker leads and speakers first to avoid confusion with restoring to same configuration.
L and R is good enough, masking tape suitable.
[i] Swap entire driver / lead assemblies.
Does left channel still not work?
If so then problem is amp.
If fault now swaps to R ch then amp is ok - problem external.
Return to original L&R config.
[ii] Disconnect leads at speaker ends only (power off).
Swap drivers only so leads are still same L&R but drivers now R&L.
Power up and test.
L channel fault = lead or connector fault.
R channel fault = driver fault.
With a multimeter:
Check buzzer-continuity of leads + + & - - end-to-end.
Check ohms of speakers closely match specified impedance.
Dec 19, 2017 | Audio Players & Recorders
Jensen 300 watt 2 channel amp model xa2150
Get into this link. You can download the operation and installation manual to your Jensen XA2150. It is absolutely free download. If you fail to get it downloaded, inform me by Fixya comment box, with your email address. I've the downloaded manual with me, and I'll send a copy of it to you by return mail. OK
Please don't hesitate to rate this solution.
Dec 23, 2011 | Car Audio & Video
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
If you are using Internet Explorer: click tools at the top, then internet options, then security. Click "Custom Level" button, go to the scripting section and disable active scripting. Then Log in to your yahoo mail. Select "Return to a previous version of Yahoo! Mail" Once done you can return to the previous settings. Log out and login again.
If you are using Firefox go to tools > options > content. Click on disable Javascript. Then Log in to your yahoo mail. Select "Return to a previous version of Yahoo! Mail" Once done turn it back on. Log out and login again.
Aug 14, 2011 | Yahoo Mail
I have a Pioneer VSX-D412 reciever, and connot get my b channel to work. Only my A channel works, and I'd like to get both or all 5.1 working. And no I don't have the manual for the system.
In case you didn't see this on the other post, it is not the function of unpaid Fixya Experts to do the web searches for or read the manuals to those who can do it themselves. Most questions submitted to us would find answers immediately if they were typed directly into a search engine.
If you don't have the manual I recommend you get it. There may be other questions. A search for "Pioneer VSX-D412 manual" finds it.
What sources fail. How is it with test tones? have you isolated (swapped) the speakers?
Here is the service manual if you should ever need it.
Aug 04, 2011 | Pioneer VSX-D412 Receiver
Weak output on one channel when playing CD using the auxiliary input.
Swap the input cable channels to determine if it's the unnamed CD or the unnamed receiver. Try (or swap) other cables, inputs, sources, speakers.
Continue from there. Hint: name things if you want specific help. Look at manuals.
Jun 18, 2011 | Audio Players & Recorders
I got a new Sanyo Vizion 46" LCD tv as a present about 2 weeks ago. I noticed since the first day when I change channels I can still see some images of the previous channel I was watching. Should I...
Return the tv for another one for the replacement.This tv have a problems,call a delay prograssive scan.That why u see the jet trails of the previous pictures.This problems,will not go away,but will getting worse and even might have a permanent pictures screen burn of the previous pictures in LCD screen panel too.
Nov 29, 2010 | Sanyo DP46849 46 in. HDTV
If you look on page 48 & 49 of your LG TV’s user manual, you will see your TV remote and a description of the buttons.
Your particular remote does not have a previous channel button or function. That backwards arrow button is to return one step in an interactive application or other user interaction functions.
However, if you get the full size LG TV remote it does have a “FLASHBK” button that will go to the prior channel. Some programmable TV remotes have this feature too.
You can go to the TV store and ask to use the larger LG TV remote that has the “FLASHBK” button on your TV on display to see if your TV will perform that function.
Good luck.
May 21, 2010 | LG 42LH200C LCD TV
Lost volume
check the power amplifier IC at the audio section
Feb 01, 2008 | Samsung DLP HL-P5663W 56" TV
Maxent MX-42V1 42 in. Plasma Television Logo
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
