Question about Kenwood KDC-2025 CD Player
NO SOUND COME FROM INSIDE SPEAKERS ONLY LOWS PLAYING THRU SUBS
  • Anonymous Jan 30, 2009
    Kenwood KDC-1020. No sound on speaker terminals, the Auxillary output or Subwoofer output works.
Try wiring the speakers up directly to the stereo instead of the wires that are already in the car, if it doesnt work then give up
Posted on Apr 22, 2009
Why can I only hear bass thru speakers when playing in my car
there is a adjustment you can make . most times on the volume knob by pushing it in .you can adjust the sound .
Nov 12, 2014 | Computers & Internet
I use a Mackie 1604vlz board. I have Passive EV Speakers that I use a QSC power amp for. I want to add one Powered Subwoofer to this. How can I hook up without buying a crossover? Can I run out frome the...
You can, but I would not suggest it. Depending upon the input design of the powered sub, the highs might not get filtered out. Many subs assume that they are only receiving the lows. You are better off using a crossover between the mixer and the amp for highs and the powered sub for the lows. Please note that the crossover will give you much more control over the sound quality.
Dan
Mar 29, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Can i connect the pv 112 to the pv 118 subwoofer since the powered mixer i bought it only has 2 main outputs? The powered mixer I bought is the PV XR 8600D powered mixer...
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
Dan
Dec 09, 2010 | Peavey Pv118 1x18" Subwoofer Speaker...
Is the sub out strictly for a powered sub or is there a way to hook up speaker wired subs to that
The sub out connection is for powered subs. To use a sub that runs off of the amp power, you'll will have to run it through the main speakers. Usually, on this type of sub, there are connectors that allow the frequencies above the sub range to bypass it and go on to the main speakers (the sub filters the lows and passes the highs on to the speakers). If your sub does not have this, then you'll have to get a separate amp for your sub to run off of the sub-out.
Dec 01, 2010 | Sony STRDH710
Popping noise on my 12" type r subs
The subs are making that sound when the bottom out + when they reach full excursion be careful if it keeps happening eventually your subs will fail because you will end up damaging the subs voice coil.
Happy Booming
Apr 20, 2010 | Alpine Type-R SWR-1222D Car Subwoofer
I Have a Gem Sound EVA3955 amp an TR-150 subs sub stop wroking
Yes and Yes. If bypassing that noise filter, has no effect your subs could have blown.
Jan 05, 2010 | Car Audio & Video
JBL PB10 has lost power even though still plugged into wall, any suggestions?
Do you mean like the subs power lights dimming when playing it at volumes it once had no problem playing, or loss in sound, distortion?
Oct 10, 2009 | JBL PB10 Subwoofer
I HAVE A NEW AMP AND SPEAKERS, AND THEY DONT SOUND ANY DIFFERENT.
if you dont have a crossover you will not get the best performance out of your sub. you need to seperate the frequencies and send only the lows to the sub woffers.
Aug 25, 2009 | Car Audio & Video
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
Kenwood KDC-2025 CD Player Logo
65 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
