Question about Samsung Televison & Video
High pitch sound from 50" projection TV monitor. It's not either fan unit, because that's what it sounds like. I have disconnected both fans and the noise is still there.
  • Aanddcarr Jul 05, 2008
    Settings don't have anything to do with this problem. This is a bearing or something. I thought it was one of the fans because it winds down after the power is cut off. I was thinking maybe the color wheel?
    I just wasted ten dollars...............
    Genius:
  • 1,447 Answers
Hi-
If its a hi pitch sound chances are its not recognizing the source or signal- try reconnecting cables and setting programs on the projection tv-
Keep us posted- thanks!
Posted on Jul 05, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jul 05, 2008
    I would agree on that but that's hard to check on too, if the product is within warranty pls call manufacturer, if not then you can have this checked or service. thanks
    you can try pressing on S.mode as well or set it to standard mode using the remote
I have a 50" Samsung Tv. Model Number:
Some of these (many) had issues with a color wheel---high pitched or fan light sound that declines when set turned off----Got this?
Nov 04, 2012 | Televison & Video
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
WHEN I TRUN OFF THE TV IT MAKES A NOISE LIKE SOMETHING IS TURNING AND RUBBING SOUND.
2 solutions for problem. ONE color wheel is grinding. IF high pitched sound is heard. Second bad fan or fan contaminated with dust. Turn TV off unplug. LET cool down ... Using canned air clean all vents on rear of set. MAY also need to remove cover and find the 3 fans inside of set.
Feb 16, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a samsung hln507 and there is no picture. we start the tv, it has a high pitched whining sound, the fan and the color wheel are spinning, but there is no picture. after about 10 seconds the tv turns...
The colors wheel is dead.That why,u hearing high pitched whining sound.The colors wheel is spinning off of is motor axis and grinding it sides walls,that where the high pitched whining sound came from.Hire a tv Tech. for the colors wheel changing,because it requiring to take out alots of the machanicals parts itself,before u can come to the colors wheel itself to change it.
Oct 16, 2010 | Samsung HLN507 50" Rear Projection...
Screen suddenly turned off, makes an odd high pitched noise when it tries to turn back on. power button flashes orange
Sounds like there is a power problem if the neutral (return) wire on the power supply has become high impedance (or even disconnected) then you will get a high pitched sound coming from the TV PSU also the voltage that is presented will not be 240V which will give you the same problem.
The orange power button means standby if you fix the PSU then the TV might work again but it may have been damaged by the PSU.
Jan 07, 2010 | Panasonic PT-50LCX63 50" Rear Projection...
Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
Nov 23, 2009 | Samsung HLN5065W 50" Rear Projection...
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
High pitch sound
If the sound goes away when you turn it off, its the colorwheel. If it keeps running for another 1-2 minutes (cooldown) then its a fan. Both are changeable by a technical person, the colorwheel being much more intensive disassembly. Let me know if you need help there.
Dec 16, 2008 | Samsung HLN5065W 50" Rear Projection...
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Televison & Video Logo
35 people viewed this question
Henry  Thomas
Henry Thomas
