I have everything installed but it keeps saying Code 10 error on the MTP device.
  • Anonymous Dec 21, 2008
    code 10 error not detecting my mp3 player
  • Anonymous Dec 30, 2008
    Same problem, works on my other computer.
    Very frustrated
  • 8,596 Answers
Uninstall the software that came with the CD, and reinstall the software that is one the company's website.
Posted on Jul 05, 2008
Accidentally deleted everything on sansa e250 computer can't see device.
Hi there
I can understand issue. When you say the device is not detected. Then it could be an issue with the system files would have got deleted because of the format.
To fix this issue, i would recommend you to keep the device in MTP mode ( Menu->Settings->USB->MTP).
Connect the device to the computer.
It will give the message as Found New Hardware.
Go ahead and install the MTP drivers by following on screen instruction.
Then Unplug the device.
Restart the computer.
Connect the device.
Now we are offset and device will be detected.
IF still you have issue kindly revert..... Good luck
Feb 18, 2010 | SanDisk Sansa e250 MP3 Player
An mtp device cannot start due error code 10 whats that
I solved the code 10 problem on my vista 64 by using Revo uninstaller on the next to highest level to remove Acronis 10.4942 After this all media readers appeared and worked. A later version of Acronis Emergency boot disk still works to backup/ restore my system
May 06, 2009 | Creative Labs Zen Micro MP3 Player
Can't use VPC-CG9 as PC camera.
I don't know why this wouldn't work on Vista HP, but this excerpt from the manual suggests that your XP SP1 Pro would not work without the SP2 rollup:
"Please perform the following upgrades before connecting the camera to a computer.
-Upgrade Windows XP to SP2.
Install Windows XP SP2.
-Install Windows Messenger 5.0 or later version.
Download Windows Messenger 5.0 or later version, and install it.
-If using MSN Messenger, please install MSN Messenger 7.0 or later
version."
Perhaps if you are following the steps exactly in the manual and it still does not work, upgrading Messenger will magically help.
Mar 24, 2009 | Sanyo Xacti VPC-CG9 Digital Camera
Driver
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??)
2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer   3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC   4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on).  5. Try other modes as well.
Keep the device in AutoDetect Mode and follow the instructions below:
i. Connect your Device
ii. Right click on My Computer and select Manage
iii. Select Device Manager
iv. At the right hand side look out for Portable devices and click on the + symbol to display your device
v. Right Click on the device and select Update Drivers
vi. Select 'No, not at this time' and click Next
vii. Select 'Install from a list or specific location' and then click Next
viii. Select 'Don't search, I'll choose the driver to install' and then click Next
ix. Select 'MTP Device' and then click Next. This should install the device and then should be ready for use
Jan 17, 2009 | SanDisk Sansa m240 MP3 Player
I have a Gigaware 4GB MP3 GX400 4-420
Download the drivers from Creative Labs, or with the disk included with the MP3 player.
Dec 27, 2008 | Creative Labs ZEN Vision:M Digital Media...
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Sansa m240 computer connection cuts off in MTP mode with device cannot start error message in the device manager
Uninstall all Sansa software using the add/remove programs function, and then reinstall it.
Sep 22, 2008 | SanDisk Sansa m240 MP3 Player
MTP Error
When the YP-K3 2 gb device is plugged into the USB Port, the system says "Found New Hardware, Samsung YP-K3" which then switches to "MTP Device" and then fails on an MTP error. It seems to be searching for a driver, and cannot find one. H E L P!!!!!
Dec 29, 2007 | Samsung YP-K3 MP3 Player
MTP DEVICE Sony 4gb walkman NWZ-S616 not installing
if you have a problem about MTP Device and wont be able to show in your "My Computer", here are tips that may help you fixed your problem:
*First- Uninstall the MTP Device Driver in your system.(Right click My Computer then manage, then click Device manager at the left part, then after that, find MTP Device in your right part, then click and Right click the name of your MTP Device then uninstall.)
*Second- Reconnect the device and then after a pop-up show which says, New hardware found,
click install the driver in a specific location, then choose the bottom option and then choose
Storage Device.
*Lastly- Turn On your Device and search it in My Computer.
that's all, and i hope i do a little help to you!
Mark Anthony Quintana
Dec 09, 2007 | Audio Players & Recorders
122 people viewed this question
 Grubhead
Grubhead
