Question about PC Chips (M863G) Motherboard
PC Chips M863G Audio 1 Jumper Settings
I have recently installed this motherboard and I removed the jumpers off the Audio 1 pins and I can not for the life of me remember how they were set.
  • Anonymous Feb 05, 2009
    well my problem is i keep getting this generic host problem and also my mozilla keeps shuting down and everything else when the generic host comes up it give me 1 minute till it shuts itself down
    President:
  • 1,314 Answers
O o
o o <---- This one
o o
o o <---- This one
o
Those are the two that should be set.
Posted on Jul 05, 2008
Bueno Tambien e tenido el prioblema con esta placa y alfin logre solucionar.
cierto es que en la pag oficial de pcchips solo existe el driver de sonido para windows 98/me/NT, mas no sirve diske el driver para WindowsXP.
Despues de Mucho Intentar k esta placa Me Diera el Sonido ;Instalando Varios Drivers De la Serie AC97 y Revisar el Chipset e Incluso la Flashear Para Ver Si al Actualizar la BIOS se Solucionaba el Problema del Driver
Bueno Aqui La Solucion:
Primero Bajas el Driver de la Pag Oficial:
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=366&DetailName=Driver&DetailDesc=&CategoryID=1&MenuID=3&LanID=0
Al Instarlo Dara Siempre el El Maldito ERROR de k no se pudo instalñar el Driver y Sale con Un Signo de Admiracion.
Luego Bajas este Otro Driver y lo Instalas :
http://www.4shared.com/file/68589949/abae1642/WDM_A406.html
Con Esto Ya Debe de Funcionar Correctamente el Sonido
Bueno es Todo Me Despido y Ojalas Sirva esta Solucion para Todos a los k haya Caido esta placa a sus manos, y Una Llamada de Atencion a los Fabricantes de PCCHIPS Por NO Hacer Un Driver Para WindowsXP Para Esta Motherboard.
Posted on Feb 02, 2009
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
Forgot the password and cannot start my laptop
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
Hope this helps
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
hope this helps
Jan 25, 2011 | Computers & Internet
Need to change mouse settings on bios but i forgot my password
use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Jan 24, 2011 | ASUS M51Ta-X1 NoteBook
I am facing a problem to install my XFX Radeon HD 4350 1GB graphics card. My PC has a intel DG31PR with core 2 duo and 3 gb ddr2 RAM. the CPU starts but there is no visual on my ACER monitor. I have...
It sounds like you need to change a BIOS setting. I don't have this MoBo, but on others there is a toggle to make the integrated graphics primary or secondary. You would need to change it to secondary. On this card this should happen automatically - so check BIOS settings and that your new card is properly seated in the slot.
From http://www.intel.com/support/motherboards/desktop/sb/cs-022225.htm
Installing External Graphics Cards
If you want to install a 3rd party external graphics card instead of using the onboard graphics, follow these steps:
  1. Install the 3rd party external graphics card, following the installation instructions that come with the card.
  2. Integrated graphics is automatically turned off.
Jan 10, 2011 | Intel DG31PR Motherboard
Bios password, how do i remove it. I need to change the boot system to install windows.
Unplug the power cord from the power supply.
The fastest way to clear the bios password would be to first find the bios/cmos battery on the motherboard. See the picture below.
Next find the 3-pin bios jumper. Asus motherboards usually mark the motherboard bios pins as, CLRTC.
It will be rather close to the bios battery. Pay attention to the current position of the bios jumper. It is currently set as normal. The jumper will cover pins 1 and pin 2.
Remove the jumper and place over pins 2 and pin 3. Doing this will clear the bios and will reset all bios settings to DEFAULT. Grab a small flat- head screw driver. Gently insert the screw driver slightly under the battery edge to help you to remove the battery. Wait 30 seconds and reseat the battery. Reset the bios jumper back to pins 1 and pin 2.
Reconnect the power supply cord. You will need to enter the bios and re-configure all your settings. Use your motherboard manual to help guide you through all your bios settings. Next time include the model number of your Asus MB.
Happy holidays!
Mike
Dec 19, 2009 | ASUS Computers & Internet
My board will power up but i cant get any video dont know where to srt jumpers
FOr reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 10, 2009 | PC Chips P23G Motherboard
How to break bios password
remove CMOS battery for 1 minute then try to install it back
Jun 08, 2009 | Intel D945GCCR Motherboard
I recently upraded my computer with an Asrock Penryn1600SLI-110dB motherboard with an Intel CORE 2 DUO E4600 processor. The symptoms are: When I tried to boot for the first time the cpu and case...
If you have recently upgraded your motherboard and when you turn it on, there is no display. You could check the jumper setting of your motherboard.
http://download.asrock.com/manual/PENRYN1600SLI-110DB.pdf
Check this site for jumper settings. Download the manual. Go first to page 11 and find clear CMOS jumper. That will be number 17. Then go to page 24 for the correct jumper settings. Jumper should be on the pins 1 and 2. That's the default settings.
If the jumper is set already to 1 and 2. Clear the CMOS by putting the jumper on 2 and 3. It should be off when you are going to set the jumper. This is to make sure that the settings for your motherboard is set to its original settings.
If you are going to clear the CMOS settings, you will have turn the computer on after clearing it and then turn it off again. Put the jumper back to pins 1 and 2. Now make sure that computer is totally off. Uplugged the computer just to make sure when you are doing this.
Note:
To test also the motherboard if it is working, do not connect the other pheriperals such as network card, sound card, and other cards that is not buit-in. Also drives such as Hard Drive and CDROM drives.
Check for beep codes. Short beeps tells you that the Video card is not inserted properly. Long beeps tells you that the memory card is not in place correctly.
Just remove the Video card or Memory card and then place it back again.
Computer should be off as well when doing this.
Sep 09, 2008 | Computers & Internet
Boot problem
Updating the BIOS could be the solution, but, let's leave that until last - if you get it wrong, you'll stuff up your machine (mobo) for good.
Don't worry about the CMOS jumper, it is there to clear the CMOS memory, but I don't think you need to do that.
Can you get into your BIOS during start up OK? (usually by hitting F8, F2, Del one of these keys or similar during start up, it should tell you which).
If you can navigate your way through the BIOS settings ok, don't change anything you're not familiar with - another place you can do damage, and somewhere towards the end, where you have to option to exit BIOS with or without saving there should be another option like "Reset Defaults" or "Load Optimal Settings" or "Set Last best Settings" or something like that.
Click on this then exit your BIOS. Your computer should restart.
Make sure your new memory battery you put in is up the right way, if it's upside down it could be causing a short - the usual way is positive up, that's the whole flat face with the writing on it - the insulated button side is negative (down).
**.The best way to acknowledge contribution is to rate it's relevance.**
Sep 07, 2008 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Pc chips m811
try to reset the BIOS to default either take the M/board battery out for at least 1 hour reinsert battery and try or
On M/board will be writing with reset bios or similar usually a small 2 pin connector with a jumper on 1 pin connect jumper over both pins remove jumper refit over 1 pin and reboot
If 3 pin setup remove jumper and fit over middle pin and the one it was not on replace back to how it was and boot computer
Aug 04, 2008 | ASUS K8V-MX Motherboard
PC Chips (M863G) Motherboard Logo
1,797 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Matthew Spark
Matthew Spark
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
