Question about Frigidaire Dryers
Our dryer is beeping and is displaying an error code of E68. I hit Cancel to try to reset it, and it goes back to numbers (20 minutes or whatever), then after a couple seconds goes back to E68. I hit start and it changed to E4A. We have an AGQ6000ES
  • Anonymous Sep 23, 2008
    I am experiencing the same problem...
I found via a Google search that E68 means one of the keys is jammed. Looking at it, it was pretty obvious which one, so I pushed it in and re-centered it in its casing. That did the trick.
Posted on Jul 06, 2008
E68 ERROR CODE FRIGIDAIRE DRYER MODEL NO GLEQ2152EE0. CAN YOU DIRECT ME TO A SPECIFIC PART NUMBER?
E68 for this model number says in manual that this is for a "button stuck" or held down for more than 30 seconds
ck all your buttons for one that just doesn't "feel right" when its pressed , this one will be your problem
Oct 29, 2015 | Frigidaire Dryers
Dryer codes
The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Feb 13, 2015 | Frigidaire Dryers
How do i make it quit beeping so often
Hello friend, thanks for your post!
I understand that your Frigidaire dryer is beeping and flashing lights. To reset your dryer you should disconnect power, by unplugging it or flipping the household circuit breaker, for roughly ten minutes. Which lights are blinking on your display panel? It could be providing you an error code.
If the reset does not help correct the issue, could you please provide me with your model number? Typically you can locate the serial tag (which lists your model number) on the door frame of your dryer. If you need further assistance please reconnect with me. -Matt
Sep 27, 2014 | Frigidaire Dryers
I have a frigidaire affinity that is beeping with code E68 HELP???
Good Morning Friend,
I understand that your Frigidaire Affinity dryers is beeping and displaying an E68 code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its then you press buttons and it beeps continuosly...
that's a lot of kids... according to the Frigidaire wiring diagram and codes list E68 means a key is stuck or bad board. You can enter function test mode and check which button is at fault. Hope this helps Tim
p.s. here is a thread:
http://forum.appliancepartspros.com/dryer-repair/143380-frigidare-affinity-dryer-e68-error-code.html
Apr 06, 2011 | Dryers
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
Wat is the code e68 in drayer fidiarer
Jan 20, 2011 | Frigidaire Dryers
Err68
Hi
Error E68 on Frigidaire dryer means that One of the keys (buttons) is stuck closed (active). Please check whether any button is pressed or stuck. Also try removing the lint filter and clean the contacts of the inside of the filter.
Try performing function test to check which button is at fault. Enter function test mode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists then you'll need to replace the electronic control.
Function Test--
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and “rES” will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode, the buzzer will sound 3 times and all LED’s will rapidly flash.
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power from dryer. Dryer will be reset for regular operation.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
1,156 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Electrolux
Electrolux
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
