Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon MP830 print head
Where do I go to find out how to remove the print head?
    Scholar:
  • 49 Answers
If you purchased the printer new, you would have had to install the print head before youput the cartridges in. The print head id he bit the cartridges clip into. So to remove the print head:
Open the cover, take out all five print cartridges and then lift the lever on the left of the print head and remove print head.
Hope this helps!
Posted on Jul 05, 2008
komguy
  • 2306 Answers
SOURCE: incorrect printhead
It just means that the printhead is defective, All of the Canon machines say that when the printhead goes out.
Posted on Jul 27, 2009
PcExpert
  • 293 Answers
SOURCE: Print head
Try removing the carts overnight clean the contacts then insert it in the morning and retry. Hope this helps
Posted on Sep 18, 2007
alazghari
  • 33 Answers
SOURCE: re: Canon pIXMA MP830
Hi
I think you need to check if the inkjet (print head/ Cartouch) is installed ok on the printer.
& Make sure it is the type supported by your printer.
I hope this was your problem.
Posted on Nov 07, 2008
SOURCE: my canon mp830
I replaced the print head & it worked.
Posted on Dec 12, 2008
SOURCE: canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Posted on Jul 08, 2009
Canon mp830 error code 6A00
Hi Good day!! The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Dec 06, 2010 | Canon MP830 All-In-One Printer
How do you remove print head from canon mp830 to replace
open the cover!Wait for the head to move to the center,remove your cartridges and there should be a greyish clip holding the head in place!Unclip and remove the head!
Mar 28, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Have canon mp830, suddenly will not print yellow, cleaned print head, did allignment. do i need to replace print head?
The ink color cartridge is near empty or defective.
You need to get a new and HP genuine one.
Thank you
TechSaver
Jan 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
REPLACED PRINT CARTRIDGE NOW STATES THE TYPE OF PRINT HEAD IS INCORRECT.
Canon support suggests that perhaps your print head needs to be reseated. This would be too complicated to explain, plus the documentation at Canon support has pictures to help you perform this task.
You must be willing to use the "Search" feature in order to view this solution. Type in the question:
"The type of print head is incorrect" > Click <Search>
Canon MP830 Reseat Print Head
Dec 21, 2009 | Canon MP830 All-In-One Printer
Incorrect printhead
Jul 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Print head
Some Canoin models have a builtin head assemby and the replacemt is a 'tank of ink'
Thers the cartridhe is complete with heads built in.
Which is yours?
Either Way Canon support will advise
Jun 16, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp830
Error code 5200 means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cannon mp830
Hi try to remove ink cartridge and put it back , push down the cartridge to engage will the micro chip.
Mar 09, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
644 people viewed this question
old marine
old marine
