Question about Proview PL926WBi 19" LCD Monitor
Blurred pictures on monitor
I upgraded from windows xp to vista now all video display is ****. I cannot figure out how to change the resolution. I do not have a display option in control panel. I tried to install driver for monitor from cd as my devices only show a generic pnp monitor but error message says driver is not a win32 application. I am at a loss
  • 3,940 Answers
The problem is not the monitor, it is the display adapter (Video card) of your system needs a valid Vista driver. (NVidia, ATI and Intel are the 3 largest Graphic card manufacturers) Monitor drivers are almost never needed except on some advanced large LCDs.
You said up upgraded to Vista, did you use a Vista upgrade DVD or just perform a clean installation of Vista? Have you installed Vista Chipset drivers? The chipset and Graphics drivres may not be native to Vista, you may need to install them.
Posted on Jul 05, 2008
The display of my monitor (hp w1907) is widened. A circle looks like an elipse. How can i solve this. please help.
It might tvhat there are no video drivers on the PC or there screen resolution is too big or too low
Screen Resolution Issue
Windows XP
1. Click Start -> Control Panel -> Display
2. Display Properties should appear
3. Click on the Settings Tab
4. Slide the Bar to the Left or to the right Making the picture almost a square
Windows Vista/ Windows 7
1. Click Start -> Control Panel -> Personalization
2. Click on Screen Resolution
3. Move the bar up or down until the picture turns almost a square
Or else reinstall a new video driver configure the screen resolution again
Hope this helps
May 24, 2011 | HP w1907 LCD Monitor
How can I fix an "Out of Range" display?
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Feb 09, 2011 | Westinghouse L1975NW Monitor
The display screen got smaller.How can I bring it back to normal size?
You have to change the resolution of the screen.
Right click on the desktop, not on an icon- Properties- settings- at the "Screen Resolution" box increase the value.
7fb4f63.jpg This picture is for Windows Xp.
The following is for Windows Vista:
28993d7.jpg Select display settings and a window almost the same will appear. Again increase the value.
If you need further assistance, just post a comment.
Mar 29, 2010 | E-Machines eMachines Monitor E15T4
Blurred image in Samsung Syncmaster732nw monitor
For best pictures, you need to set your PC video resolution to the native resolution of this monitor, which is 1280x1024 @60Hz. Try that first before opening up the monitor to look for bad components.
Post back, see what usually goes wrong with SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
How do I change resolution on monitor?
that is easy
go to control panel
go to appearance and themes
go to display
go to settings
near bottom is screen resolution select the resolution supported by your video card.
Nov 18, 2009 | HP Compaq WF1907 Monitor
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Text is to large on aol or any site
You need to change display resolution.
Follow instructions here if you have Windows XP: Windows XP: Change your monitor resolution
Here for Vista : Windows Vista – Personalisation of the Display Properties
If changing resolution does not work, that means that you have to reinstall video drivers, in this case submit a new question on fixya giving details on computer make and model.
Oct 23, 2008 | HP Compaq V75A (White) 17" Monitor
Proview wb926wbi monitor
Try changing the resolution to 1440x900. This is the ideal resolution for this monitor.
To change the resolution:
Right click on an empty space on your Windows desktop.
Choose Properties (XP) or Personalize (Vista)
Choose the Settings tab (XP) or Display Settings (Vista).
Slide the resolution slider to 1440x900, then click apply.
If asked whether you want to keep this setting, choose yes/ok.
Note: Not all video cards support this resolution. Updating your video card's (not monitor's) driver may add it.
Jun 29, 2008 | Proview PL926WBi 19" LCD Monitor
Pictures are blurred........... HELP
Good morning!
It sounds like your LCD display is bad and needs replaced. You can verify this by hooking up an external monitor. If the display is OK on that, then you probably need to go shopping for a new (or gently used) LCD assembly.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Nov 27, 2007 | Acer Aspire 5050-3242 Notebook
Proview PL926WBi 19" LCD Monitor Logo
204 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
