Question about Beko 24 in. D3421F Free-standing Dishwasher
Dishwasher will not cycle, stops and its filled with water.
My dishwasher will not continue to cycle, it stops and when I open it, the bottom is filled with water. It also smells burning. I checked to see if anything was stuck but I do not see a thing.
What to do what to do??
  • smoyes Jul 06, 2008
    I have a 5310 and it seems to be doing the same thing. The bottom fills with water, but nothing else seems to happen, the arms don't go round, it does not take in any rinse aid or powder, although it does eventually drain, then it just keeps running until I switch it off. Having looked at various web sites I have a feeling it may be the thermostat, but I cannot figure out how to actually get into any of the workings of this machine. Does anyone know what is wrong and also how to get at any of the items that may need replaced?
    Problem Solver:
  • 19 Answers
Try kicking it.
Posted on Jul 05, 2008
Dishwasher not completing cycles
see this causes and fix it. God bless you
If the cycle doesn't complete, check these:Water-heating cycleTimerWater-heating cycleMany dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. TimerTimers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. 9_25_2012_6_48_09_am.jpg
Sep 24, 2012 | Dishwashers
I have A bosh SKT 2052 Will not fill up to start the cycle
see the following causes:
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher) see diagram
2) faulty float switch, test for open or faulty.
see the diagram attached.
God bless you
Jul 11, 2012 | Bosch 22 in. SKT5102 Free-Standing...
My whirlpool dishwasher just stopped working the middle of the cycle with water still in the bottom and now nothing lights up or comes on and the water is just sitting in the bottom. Any suggestions?
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault and required to be replaced. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
I have a kenmore dishwasher. While it was in the
hi...
If the cycle doesn't complete, check these....
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
if still it doesn't fix your problem then see whether any error codes are generated....
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective F2 High water level · Plugged/Bad water pump
· Defective water inlet valve F3 Thermistor fault · Open thermistor
· Bad wiring to thermistor F4 Fault with water fill (only on machines with level-controlled fill)
Note: Lights blinking, pump running and controls dead indicates an over fill fault 1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
*Faults may vary by model. Use this as a general guide.
i think these details would definitely help you.....thank you...
Jul 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher not filling
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 21, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Power point dishwasher - not washing dishes
Jun 18, 2009 | Dishwashers
Water fills up dishwasher after complete maybe a day or two later
Sound like the hot water sonenoid is stuck in the open position. Locate this solenoid and tap it lightly with a small hammer while the hot water is open. If it does not stop it will beneficial to have this part replaced. I hope this will help.
Jan 17, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
Water-heating cycle
Timer
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Beko 24 in. D3421F Free-standing Dishwasher Logo
617 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
