Question about Xerox WorkCentre XE88 Laser Printer
Our copy machine keeps flashing E2. There is no paper inside the machine.
Keeps flashing E2...but there is absolutely no paper inside the machine. I've turned machine off and on...disconnected and reconnected...removed and replaced toner and drum. Any ideas?
Remove the toner and drum cartridges. Using a flashlight, look inside the front of the printer. At the rear of the cavity there are two large rubber rollers. On the floor, about an inch to the right of the rightmost roller, there's a tiny black plastic feeler that's supposed to protrude from a slot in the floor and be pushed down by paper as it feeds through. Occasionally it sticks in the down position, causing the printer to think there's a paper jam. Running a finger over it usually unsticks it so it will pop up where it belongs. I usually flick it down a few more times to make sure it's free to pop pack up. I guess the spring tension, light by design, is sometimes not enought to overcome friction.
Posted on Dec 21, 2008
  • 300 Answers
I'm fairly sure E2 relates to the registration sensor, check the paper path around the area where the paper first enters the machine from the tray, check that the paper flags aren't stuck down.
Posted on Jul 05, 2008
The display panel on the unit keeps flashing with e2 i u nderstand this is supposed to indicate that water needs draining which i have done but it keeps saying e2
E-2 means indoor coil sensor not effective. Better clean with salt paper or replace it. Hope you wouldn't had cooling. Am I right? Thanks.
Dec 11, 2010 | Convair Heating & Cooling
Hello, my name is Kyle. My printer keeps eating paper when going to print. I checked the inside of the tray and found a pen lodged inside, but it still jams. An error message E2 comes up.
There will still be something jammed in the path. You may need to lift up the paper guides to see it - even to the trained eye it can take a few minutes to spot.
Oct 05, 2010 | Canon PIXMA MP240 All-In-One InkJet...
E2 error showing
This might be a paper feed error. Try to get a thicker paper onto the feeder and check if it takes it. Try also to check the printer inside for loose parts or loose objects.
May 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My rinter keeps saying e2 what does mean
Error E2 means paper Jam and is it a Canon printer ??
Make sure you open printer slot and take out the jammed paper, it there is one.
Retry and hope it works !!
Thanks !
Sep 08, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer jam E2 with no paper
Are you sure there is not even a tiny piece of paper caught between the rollers? Most machines sense the resistants and give this message.Try rolling the rollers by hand,air spray the insides , lubricate the gears, you got nothing to loose.Good Luck.
Check Display
usually it's a paper jam. remove cassette, and look inside...there may be a piece of paper stuck inside. Also remove, and re-seat all paper in the cassette. Also, remove toner cartridge, and check inside the machine cavity for jams..
re-post if problem remains.
Jul 15, 2009 | Ricoh FAX2050L Plain Paper Laser
Brother DCP-145C. Paper jam removed. Light keeps flashing. How can I switch it off? HELP!
There will still be some scrap of paper in the machine. Get a torch and get in there. It's the only way, unless you call tech guy
Apr 28, 2009 | Office Equipment & Supplies
Flashing paper jam, no jammed paper
Check to see if there is dust on the senor inside the fax machine, blow with some air can help
Apr 22, 2009 | HP 1010 Plain Paper Inkjet Fax
ERROR E2
The most likly problem by far, it a broken fuser drive gear.
That would be in the area where is says caution, heated surfaces.
Look on the inside, back side of that assembly, and you will find a gray/black gear either broken or with some teeth missing. You may even look inside toward the back on the frame and see pieces of that gear broken. Either that, or one of the stripper fingers on that roller are bent down blocking the paper in that area..
Mar 12, 2008 | Xerox WorkCentre XD120F Laser Printer
Xerox WorkCentre XE88 Laser Printer Logo
122 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
