Question about Maytag Refrigerators
MAYTAG fRG tm-1 Both of the
MAYTAG Refrigerator tm-1 Bought in 2000 Both of the inside lights have burned out. Putting in new bulbs does not work. It appears that there is a swiTch for each light that I think shuts off the light when the door is closed. This switch is about 1/2 inches long and won't come down. Am I anywhere close in describing what happened for a MAytag Top Mount TM-1 Model MTB2148DRQ SERIAL 11313188Y THANKS IN ADVANCE JOHN BERLINGHOFF johnb@hal-pc.org 713-644-8228
  • 2 more comments
  • johnb7095 Jul 05, 2008
    THe quewstion dealth with the light in the refrigerator, not the defroster.
    This was a non answer. It was not worth the trouble of writing it
    I need to know where & what the switches are that turn the lights off when the regrigerator door is closed. It looks to me like the switches (both of them) are frozen, but I'm not even sure that what I am looking at are the off on switches for the lights. Does anyone have a picture showing the off-on switches for the interior refrigerator lights ?
    I still do not have a solution.  Your experts do not appear to be reading my question.
    How do I get the lights to work ?
    Master:
  • 638 Answers
A service technician help is required at your place to fix this problem.as the unit is to be checked properly before coming to any conclusion.
reply for further suggestions
Posted on Jul 05, 2008
    Guru:
  • 1,342 Answers
Check HERE for replacement parts.
  • Georgia B
    Georgia B Jul 05, 2008
    Have you tried lubricating them with WD-40 or something similar?
  • Georgia B
    What does the defroster have to do with the lights johnychel??
  • 796 Answers
I think your defroster is gone..
you should think of replacing it with a new one
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Maytag model MSD2651HEW replaced two refer side lights. New ones will not light
some of the bulbs you buy at the stor the sucket pease is not long onoft try to scruit more or by them from a applice parts stor they little longet and make good contact
Feb 21, 2012 | Maytag MSD2756G Side by Side Refrigerator
Maytag neptune
We had this problem and found that the Printed Circuit Board will burn out very easily. On ours the light bulb inside the door blew causing the PCB to fail. (no joke)
I was quoted $315 for a new PCB. If you look on the internet you will find that a class action suit resulted in a cash settlement for Neptune owners in Canada.
We also had problems with a Maytag side by side refrigerator. Same thing,
a Printed Curcuit Board blew. Whirlpool now own Maytag, they are no longer reliable. We replaced the Neptune washer and the refrigerator. Look on the internet for comments about different appliances from consumers. Don't
waste money on Neptune repairs, a new machine will cost less in the long
run.
Jan 23, 2012 | Maytag Neptune MAH6700A Front Load Washer
MAYTAG Refrigerator MSD2351HES upper light burned very bright for few days, then broke
The light bulb just went bad.. replace it with a new one...
heatman101
Aug 26, 2011 | Maytag Refrigerators
I HAVE AMANA FRIDGE FREEZER AND THE DOOR SWITCH IS BROKEN BUT THEY NO LONGER MAKE THE PART. ITHINK I MAY BE ABLE TO USE THE MAYTAG PART
Yes, if the maytag part fits, then it may work in the Amana refrigerator. It's just a switch that carries the current for the light bulb.
Dec 22, 2010 | Maytag Refrigerator Door Light Switch...
Where is defrost timer in maytag MSD2756GEQ SxS
Inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control
Jun 13, 2010 | Maytag MSD2758G Side by Side Refrigerator
Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
Dec 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
I need to replace the adaptive Defrost Control Board on Maytag Refrigerator Model No. MZD2766GEQ. Where is this board located?
Its Located in the top right inside corner of the refrigerator section near the back wall & to the right of the water filter.Its tough to get out but only takes about 10 minutes to replace the part
Nov 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag plus refrigerater not cold enough
If the freezer is cold and the refrigerator is warm, the unit is probably not going into defrost. Remove the back inside of the freezer and see if all frosted up. If so thaw with a hair dryer and replace the adaptive defrost assembly located inside the back of the refrigerator section. Up on the ceiling of the ref where you adjust the temp. remove thc cover by putting your fingers in the back holes and pull forward. Make sure the ref is unplugged. Remove two 1/4" head screws in the front and two phillip head screws by the lights. One 1/4" head screw straight in the back. The defrost timer is located in the far right corner. A small board 2 to 3" square. It will unplug and is probably screwed in.
Sep 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
ADMIRAL REFRIGERATOR/FREEZER BURNED
admiral is a maytag owned company which is now owned by whirlpool. so contact maytag or whirlpool. google them should be eay enough to find..
Nov 02, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
110 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
