Question about Ruud Heating & Cooling
THE AC UNIT SHUTS OFF MID-DAY WHEN IT'S THE HOTTEST. I CAN ONLY ASSUME SOMETHING IS OVERHEATING, BUT NOT SURE WHAT OR WHY.
    Champion:
  • 254 Answers
This is probably a high pressure reset on the condensing unit (outside unit). One thing you might try doing is cleaning the coils on this unit. You can do this by spraying water through the coils themselves. MAKE SURE YOU DISCONNECT POWER BEFORE DOING THIS!!!!!!!!
Hope this helps Ya
Posted on Jul 05, 2008
I have a 7kw Kohler marine generator that shuts of when boat gets up on plane New impeller New fuel filter I started it runs for a while then shuts off It takes a bit to start but runs for 20 plus hrs
I take it that this unit runs the power on board and is permanently fixed in the boat
you mention new impeller so logically that means that it is water cooled drawing the cooling water from outside (underneath the boat)
pursuing logic further if that is the case then there is a shut down circuit for the water flow to prevent overheating should the water inlet become blocked ( weeds, plastic cloth etc)
from your question and statement I would be looking in that area to make sure water flow is not restricted or the protection circuit is operational ( no corrosion in terminals and wires )
Oct 01, 2016 | Kohler Electrical Supplies
Tip
Efficiency of RV Rooftop Units Deteriorating???
If the overall effectiveness of you RV Rooftop AC seems to be much less than the day you bought, here is a simple procedure to keep it running cold and prolong the life of the unit.
Problems:
1. Air seems to not be blowing as cold as before
2. Compressor trips breaker during the hottest part of the day
3. Air at night works just fine but is lacking during the day
These problems can often be solved by simply cleaning out the condenser coil of the upper unit. You will need a phillips screwdriver and a water hose with a nozzle on it.
- Remove the upper shroud from the unit
- Gently spray water through the condenser coil watching from the fan side. BE CAREFUL, do not spray with too high of pressure nor sideways. Make sure you keep the nozzle spraying directly at the coils.
- Once the water begins to flow clearly through the condenser, you should be good to go. Make sure you get as much of the condenser clean as possible.
This will save the life of many RV Air Conditioners.
on Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
Tv randomly turns off. Not sure if it is overheating or if something is broken.
It sounds as if you are having problems with the AC Power reaching the television. Please verify the cord is firmly seated the tv's ac inlet
Also check the wall outlet (and power strip) by plugging in a lamp into it and see if it flickers when the tv shuts off.
Good Luck!
Rich Lilja
Mar 21, 2015 | Televison & Video
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
2001 xterra overheating
Hi, you mentioned a clutch fan? I belive they have an elec. Fan. Have that checked.
May 01, 2017 | 2001 Nissan Xterra
I need a electrical wiring diagram for a 2007 hyundai tucson air condition system
my car is hyundai tucson 2011
there is some aircondiditioning problem condenssing fan is working but compressor is not working
Jul 18, 2012 | Hyundai Tucson Cars & Trucks
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
RUUD AC cycles warm & cold 24/7
Hello Anna Sounds like the compressor is overheating and stoping on overload internally.Then it cools down restarts and runs into overload again.I would like to see the freon pressures when running.Could have a clog/restriction in piping.I dont like that you went thru a compressor already, the original installition is suspect.The original (1st) failure cause must be corrected.Check the TXV valve replace, filter/dryer look for a kinked pipe are ideas for overheating.Make sure condenser coil is free (ari flow)& clean also.
Jul 30, 2010 | Ruud UBHC Air Conditioner
HP PAVILION ZV 6000 SHUTS DOWN AFTER LESS THAN FIVE MINUTES
Is this on battery or power supply?
If on AC power supply, then it sounds like a heat related issue.
Make sure you can hear the cooling fan running and you may need to blowe the dust out of it with a can of compressed air.
Dec 31, 2007 | HP Pavillion ZV6000 Notebook
Heating & Cooling Logo
87 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
