Question about LG WM2688HWM TROMM SteamWasher
Drain line lg tromm
I have to replace the drain line on my lg tromm wm2277h but i cant figure out how to get the front cover off to get to it?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 42 Answers
Its a pretty complicated process to take off the front panel, you will need special tools for this problem, i would bring it to a professional, the easist way is to lay it on the back side and go from there, if not like stated above bring it to a pro.
ps:drain lines hardly go bad on LG's hmm,if it's leaking then it might be the internal supply lines on the top.
just a hint,
shoots dave
drsn777@hotmail.com
Posted on Dec 12, 2008
Lg tromm front loader will tumble but wont spin
Open the access door at the bottom left corner of your washer. Use the small hose there to drain the remaining water from the machine. Un-screw the big knob next to it and pull out the attached filter. Clean out the filter and re-install. If the filter was clear, replace drain pump motor.
Mar 15, 2011 | LG WM2277H Front Load Washer
On my front loading LG TROMM i washed several floor mats and now it keeps flashing "OE" i have drained the water out but cant get it to rinse properly>>>any ideas?
The "OE" code indicates a slow drain error and is generated if the water has not drained within 10 minutes. Check the drain line for kinks or obstructions and check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure that nothing is clogging the pump like the occasional stray piece of clothing. Check the pump impeller. Make sure there are no broken or missing blades and that the impeller will spin freely. If there are any broken/missing blades or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it is nothing more than a clogged drain line, pump, or a jammed impeller. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
Drain problem
check he pump and see if theres something stuck in it. you should be able to tell if theres a sock or somethingsyuck in it.
Feb 03, 2009 | LG WM2277H Front Load Washer
Washing Machines Logo
240 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
