Just wonder why you gave me ONLY 2 thumbs up for the actual assembly manual for your telescope?Just wonder why you gave me ONLY 2 thumbs up for the actual assembly manual for your telescope?
You can't post conmments that contain an email address.
Hi Douglas, I'm glad to help. My first suggestion is to get to complete shaft. This way you want have any problems later on. It's not that much more expensive and you'll be glad you did. Below is the procedure for replacing them.
FRONT DRIVESHAFTS
REMOVAL
Raise vehicle on jack stands or centered on a frame contact type hoist. Refer to Hoisting in the Lubrication And Maintenance section of this manual for the required lifting procedure to be used for this vehicle.
Remove the wheel and tire assembly from the vehicle.
Remove the wave washer Wave Washer from the end of the stub axle
CAUTION: Wheel bearing damage will result if after loosening hub nut, vehicle is rolled on the ground or the weight of the vehicle is allowed to be supported by the tires.
With the vehicle's brakes applied to keep hub from turning, loosen and remove the stub axle to hub nut.
Remove the disc brake caliper from the steering knuckle. Caliper is removed by first rotating top of caliper away from steering knuckle and then removing bottom of caliper out from under machined abutment on steering knuckle Brake Caliper Mounting To Steering Knuckle
Support disc brake caliper assembly by using a wire hook and suspending it from the strut assembly Correctly Supported Disc Brake CaliperDo not allow the brake caliper assembly to hang by the brake flex hose.
Remove nut attaching outer tie rod end to steering knuckle Removing Tie Rod End Attaching NutNut is to be removed from tie rod end using the following procedure, hold tie rod end stud with a 11/32 socket while loosening and removing nut with a wrench.
Using a pry bar, separate steering knuckle from ball joint stud Separating Ball Joint Stud From Steering KnuckleNote: Use caution when separating ball joint stud from steering knuckle, so ball joint seal does not get cut.NOTE: Care must be taken not to separate the inner C/V joint during this operation. Do not allow driveshaft to hang by inner C/V joint after removing outer C/V Joint from the hub/bearing assembly in steering knuckle, end of driveshaft must be supported.
Support the outer end of the driveshaft assembly. Insert a pry bar between inner tripod joint and transaxle case Disengaging Inner Tripod Joint From Transaxle Pry against inner tripod joint, until tripod joint retaining snap ring is disengaged from transaxle side gear.
Hold inner tripod joint and interconnecting shaft of driveshaft assembly. Remove inner tripod joint from transaxle, by pulling it straight out of transaxle side gear and transaxle oil seal Tripod Joint Removal from TransaxleWhen removing tripod joint, do not let spline or snap ring drag across sealing lip of the transaxle to tripod joint oil seal.
INSTALLATION
Thoroughly clean spline and oil seal sealing surface, on tripod joint. Lightly lubricate oil seal sealing surface on tripod joint with fresh clean transmission lubricant.
Holding driveshaft assembly by tripod joint and interconnecting shaft, install tripod joint into transaxle side gear as far as possible by hand Tripod Joint Removal from Transaxle
Grasp inner tripod joint an interconnecting shaft. Forcefully push the tripod joint into side gear of transaxle, until snap ring is engaged with transaxle side gear. Test that snap ring is fully engaged with side gear by attempting to remove tripod joint from transaxle by hand. If snap ring is fully engaged with side gear, tripod joint will not be removable by hand.
Clean all debris and moisture out of steering knuckle, in the area were outer C/V joint will be installed into steering knuckle.
Ensure that front of outer C/V joint which fits against the face of the hub and bearing is free of debris and moisture before installing outer C/V joint into hub and bearing assembly Outer C/V Joint Inspection
Slide drive shaft back into front hub and bearing assembly. Then install steering knuckle onto the stud of the ball joint assembly Steering Knuckle Separation From Driveshaft
Install a new steering knuckle to ball joint clamping bolt and nut Control Arm To Steering Knuckle Attachment Tighten the clamping bolt and nut to a torque of 135 N·m (100 ft. lbs.)
Install tie rod end into steering knuckle. Start attaching nut onto stud of tie rod end. While holding stud of tie rod end stationary using a 11/32 socket, Removing Tie Rod End Attaching Nut tighten tie rod end to steering knuckle attaching nut. Then using a crowfoot and 11/32 socket Torquing Tie Rod End Attaching Nut , tighten the tie rod end attaching nut to a torque of 54 N·m (40 ft. lbs.)
Install disc brake caliper assembly on steering knuckle. Caliper is installed by first sliding bottom of caliper under abutment on steering knuckle, and then rotating top of caliper against top abutment Brake Caliper Mounting To Steering Knuckle
Install disc brake caliper assembly to steering knuckle attaching bolts Front Disc Brake Caliper Attaching Bolts Tighten the disc brake caliper assembly attaching bolts to a torque of 22 N·m (195 in. lbs.)
Clean all foreign matter from the threads of the outer C/V joint stub axle. Install the washer and stub axle to hub/bearing assembly nut on stub axle and securely tighten nut.
Install front wheel and tire assembly. Install and tighten the wheel mounting stud nuts in proper sequence until all nuts are torqued to half the required specification. Then repeat the tightening sequence to the full specified torque of 135 N·m (100 ft. lbs.)
Lower vehicle.
With the vehicle's brakes applied to keep hub from turning, tighten the hub nut to a torque of 244 N·m (180 ft. lbs.) Torquing Front Stub Axle To Hub Nut
Install the spring wave washer on the end of the stub axle.
Check for correct fluid level in transaxle assembly. Refer to Group 21, Transaxle for the correct fluid level checking procedure for the type of transaxle being checked.
Set front toe on vehicle to required specification.
I think I already answered this question. Eyepieces are NOT assembled they are one piece like this picture: http://www.amazon.com/Celestron-93342-17MM-Plossl-Eyepiece/dp/B000YKZKNI
They simply slip into the hole of the focuser -- straight in. The larger the number written on the eyepiece the LOWER the magnification.
In the picture above there is a metal triangle holding the tripod legs apart-- it is called a "tripod spreader" or a tripod "tray"-- used for holding eyepieces and other small pieces of equipment while you are using the scope.
Generally sold as a non-repairable assembly, same as most other tripods.
Same applies to loose 'spare parts'.
Many tripods are simply 'rebranded' to whatever name appears on them.
In terms of time and trouble trying to find a loose quick release plate, it might be quicker and cheaper to replace the entire unit.
Welcome to the disposable age.
Best bet would be to contact the manufacture directly, if the tripod is still under warranty, they should be able to replace the entire tripod for free.
If you are in the USA call 800 735-4373. You will probably have to send the tripod in but they will direct you. The VT 806 is being discontinued and replaced by the HD444
