Question about Western Digital (WDXB1200BBRNN) 120 GB Hard Drive
I need help please
I have a 120 GB WD portable hard drive (the one that just has a USB 2.0 connection no power cord) and it use to make a clicking sound when i plug it in. Now when i plug it in it doesnt click but make a sound like its reading snd the drivers install but nothing displays in My Computer. I have valuable information on it that needs to be backed up please help me...
  • 1,006 Answers
Did you tryed in another computer???Does it work???Try it and let me know for the successssss?
Posted on Jul 20, 2008
When hooking up my 120 Gb external hard drive to my laptop, I noticed there was an additional power supply required, DC by the look of it. I can't seem to find the correct size of outlet, or even an...
hi
The SimpleTech SimpleDrive Portable external hard drive features a USB 2.0 interface for speed and plug-and-play connectivity. The hard drive is USB -powered, so no extra power supply is needed.
please send me 4 thumbs up
Jul 16, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
When I plug the wd elements 120 gb portable hard drive into the usb port nothing happens
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 16, 2010 | Western Digital (WDXB1200BBRNN) 120 GB...
Light comes on but computer doesnt show
Try the following steps:
1. Plug the USB Cord into another USB Port on your PC
If no result then
2. Replace the USB Cord
If no result
3. Try connecting it on another PC
Aug 05, 2010 | Western Digital WD Passport 250GB Portable...
Missing cord
This is a USB cable, can be purchased at most any computer or electronics store.
Apr 02, 2010 | Maxtor OneTouch III Mini Edition 120GB...
When I connect WD 250 GB external harddisk ..I am getting error message" USB device Not recognized due to malfuction"..please guide me my laptop is toshiba and operating system is windows xp
Please trouble shoot by trying the device on another laptop.
If it works on another system, it simply means it is not compatible with yours and you have to get a device that is compatible with your toshiba system.
Good try.
Oct 17, 2009 | Western Digital WD Passport 250GB Portable...
SeagateFree Agent Go 120 G.B external portable hard drive When I connect that in to my lap top (HP Pavilion) windows can recognize the hard drive and once I connect that same one in to my desktop windows...
you will need to install the drivers for your drive.
xp doesn;t recognize 2.0 usb unless you install drivers and have a usb 2.0 port
but install the drivers and you should get it to recognize
you can go to control panel, system and device manager.
look for a usb device that is not working and right click install drivers or update drivers.
See if it comes up.
Once it does you will see it in the device manager under disk drives
Jun 05, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Jul 29, 2008 | Western Digital Passport WDXML800UE...
Western Digital (WDXB1200BBRNN) 120 GB Hard Drive Logo
89 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
