Unit outside is not blowing but the blower im side is no cool air
  • stephend26 Jul 05, 2008
    yeah i have the same problem i have not had it serviced i have it scheduled now but i would like to know if there's anything i can do until then
I have a similar issue. I am going to check the condensor overflow switch (at the air handler) and will verify that the blower motor overload switch does not need to be reset.
Posted on Jul 05, 2008
Why is my heil Air exchanger fan not blowing
Sounds like you may have a bade blower motor.
Aug 17, 2014 | Heating & Cooling
I have a Ruud heat pump/air conditioner. The out side fan and unit works fine and cools fine but now the inside fan that blows the cool air in will not turn on. We can turn the fan with our hand so I don't...
You didn't mention if you checked for 115 volts at the power supply to the air handler. The unit outside has its own power supply. A lot of times the switch that is on the wall doesn't like to work after its been turned off and back on for service, also check the blower door safety switch. If the blower door hasn't been put back in place properly and snugly it will kill power to the whole air handler. Hope this helps. Good luck
Jul 31, 2013 | Ruud UBHC Air Conditioner
My home air conditioning unit only blows cold air
You have an air flow problems. Clean the outside condenser coil I use on half baking soda and one half joy soadp squirt this on the coil take a coil brush that you can buy at any hardware store. and go up and down on the coil. then take the water hose and squirt it down to clean the soap and dirt off, It this doesn't solve it you will need to clean the fan blower motor the squrrel cage but don't get the motor wet. Next you will need to clean the evaporator coil just take the coil brush and go up and down to clean. This should solve your problem, What kind of readings did you get on the low side and high side. You should have a 40 degree drop across the evapartor. And the high side should be the out side temp and 30 degrees. If you have any questions you can email me at crislsparks@gmail .com. What kind of freon does it the unit take. It will tell you on the nameplate on the outside unit.
Jun 25, 2010 | Ruud UAKA042 Air Conditioner
I tring to change thermosat I can not remeber what color go where
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Heating & Cooling
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
The Outdoor unit will be easy 1st diconeect power at panel, or disconnect box near unit. Remove top of unit, be careful not to damage fan blades. Spray coils (fins) with a light degreaser let is soak for 5 mins. wash out coils from inside the unit out. Spray straight on so you push the dirt out the other side.
Re assemble and start up.
Indoor coil will be accessed by removing front cover and you may have another cover to expose the inside of the coil fins. That is where you need to clean. Spray degreaser on coils and rinse off. If its gunked up then use a wire brush 1st. Carefull not to bend the fins over.
Check the drain pan at bottom of the coil to be sure it's not full of stuff. Blow out if needed.
You should be clean and ready for the season
Jul 02, 2009 | Ruud Central System Air Conditioner
My inside air conditioner fan isnt turning on whats wrong?
If the in side blower motor turns off with the out side unit normal operation if the thermostat in the auto position set for cooling If the out side unit run with out the in side unit the out side unit will be wrecked . sounds like you need service and have it cleaned for best performance . Tom
Jun 17, 2009 | Heating & Cooling
AC unit outside turns on but no air blows through the vents
The first problem sounds like the wiring is wrong up at the heating unit not turning on the blower fan in the heater when you call for cooling. Most typical is either something has chewed the wires or the wires have been stripped b something else. The AC not cooling your house can be either it is low on freon or the system is to small for your house. Also check your filter and make sure that it is not blocked and everything is clean with the filter
May 28, 2009 | Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
