Targus laptop ac adaptor is not recognized by laptop all the time i have to wiggle connector for it to work
  • 667 Answers
Hi theetum - Is that a Targus with the interchangeable tips? If the tip is tight but still has wiggle while it's connected it sounds like the dc jack on your laptop. It's a board inside that has the pin on it that goes inside the connector on your ac adaptor. You can repair it yourself if you feel up to it or have it done by someone for about $50-75. If it's the Targus adapter with changeable tips and the tip is loose you can buy a new tip for $6. Look on the tip and it should have a number like 1,2,3,4,etc. If I sufficiently asnwered your question PLEASE rate this as fixed. If rating as helpful please don't rate at all as it only hurte my ratings. If you need further help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on Jul 05, 2008
  • 197 Answers
Its not your ac adaptor its the connector in the laptop it eather has to be fixed or replaced
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
HI there! I am using a targus universal wall power adaptor for laptops, it has an output of 19.5 V and 90 W. I was wondering if I could use this to charge my UK laptop from ADVENT. The charger for this has...
The wattage is to different, the wattage for the adapter is 90watts, and the charge for the advent is only 65w.
You can always try it, but you risk damaging your battery, or motherboard.
Jul 16, 2011 | Targus APA30US AC Laptop Charger AC...
I have the targus model APM65US DC auto/air adaptor and various tips. Which tip/connector is compatible with a Dell Inspiron miniu 10. Several look like the right size: #s 102, 104, 206, and 207. Which...
I know this sounds odd but use whichever one is the best fit and works. Also I suggest that you compare them carefully with the original noting differences in length, diameter and construction.
I think you will find that one fits better than the others.If it works and you don't have to push too hard to locate it, and it stays in firmly and connects OK then it will be fine.
regards
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | Targus APM65US Auto/Airline/AC Adapter -...
Ac power doesnt work only in battery mode,adaptor output is ok
sounds like the power connector (where you plug into pc) is going bad. try twisting / wiggling connector. pause for a few seconds between twists to give circuitry chance to reconize power input. sometimes there is a green led that will light up when power adaptor is inserted. you can use that as a reference.
Jun 03, 2009 | Computers & Internet
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Ac adapter
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
The laptop would have to be taken apart and the DC connector resoldered.
This would cost $75 - $100. Enter your zip code in the box on the right hand side of the FixYa page to find someone close to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 17, 2008 | Dell Inspiron 1501 Notebook
Charging my asus 701 laptop
Usually what happens is that the ac connector on the laptop get loose. It happens when you wiggle the ac adapter out rather than pulling it/pushing it straight in. You can check if this is the problemsby
powering off the laptop. Insert the ac adapter. just slightly wiglle it. if it wiggles at all, then this is the problem. It can be fixed by resoldering the connector back on the System board, which entails taking the laptop completely apart.
Thanks, Joe
Oct 12, 2008 | ASUS Eee 4G Notebook
I bought a targus ac adapter, it worked the first time I charged my Dell 5100 Notebook computor, now a message comes up saying it doesn't recognize the ac adaptor, how can I fix this?
AC adaptor may not be correct. Check label on AC adaptor with label on notebook for voltage (e.g. 19.5V or 20V) and current (e.g. ??A or 90W)
Voltage must be same and current must be same or higher on ac adaptor.
Aug 09, 2008 | Computers & Internet
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Notebook smells like burning plastic.
cud be your onboard voltage regulator for the battery charging. if you remove the battery and use the external power source does it smell also?
if the battery charges normal out of the unit, and the laptop works well with the AC power unit without the battery, then it's your voltage regulator for the batt charging
Mar 17, 2008 | Computers & Internet
Open Questions:
Dial[ _[1$877$7788969]_]Blackbaud mail customer careUSA? Blackbaud Email CustomerTechnical Support 1-877-7788969 Contact number. Get any of troubles facilitate via contacting Blackbaud Email technical support Number1-877-7788969. North American nation 1-877-7788969 24/7 Blackbaud Email TechnicalSupport Toll free number 1-877-7788969 for password recovery and counter hacking solutions: The users will simply recover and even reset their email account passwords with the assistance of the support center at Blackbaud Email Customer Support Toll free number we'll support you fastly and solve user problem.By approaching the toll free number 1-877-7788969 accommodated the help of consumer you some help with willing be related to the authority Blackbaud Email specialised bolster focus. Structure here you'll pay special mind to the arrangement of any issue with reference to Blackbaud Email. it's unlikely that you simply get expertise with issue whereas utilizing the Blackbaud Email nonetheless it's perpetually nice to stay precautions somewhat going for cure. On the off probability that you simply keep the helpline number 1-877-7788969 with you then you'd have the capability to realize the bolster group at no matter time and from anywhere. Blackbaud Emails service center number,Blackbaud Email customer care number,Blackbaud Emails support contact number,Blackbaud Email usa support number,Blackbaud Email Customer support number,Blackbaud Email technical support.
May 26, 2017 | VIA Computers & Internet
Computers & Internet Logo
79 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
