Question about Acer Aspire 3680 Laptop
(please i'd really appreciate help?) acer aspire 3680 !
Sorry peoples ive posted a couple of these but i keep getting new problems..
now when i turn it on, it has the regular startup screen that says acer in blue, then it goes black and some white text flashes really quickly once but i cant read it. then its all black and it wont do anything else or let me press anything. what can i do? (i dont have the reboot cd)
  • 1 more comment
  • Anonymous Mar 12, 2009
    I have a similar problem with my Acer Aspire 3680. The original Hard Drive Dropped Dead, was not visible in the BIOS at all. After some reasearch I found I could upgrade to a larger hard drive 160GB. Installed the hard drive, it visible in the BIOS, but when trying to create a partition theres only 21GB available. Acer says these machines are only able to read 80GB, if thats true why is the 160GB HD available for these machines or are they blowing smoke up my skirt. For the record I tried installing ME it was able to see the larger hard drive, but crashed during component install. Anyone have a similar situation and/or resolution for this problem or would it be best to use the laptop a chock to keep my car from rolling down hill?
    Signed
    No hair left to pull out.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Just to clarify - those things listed in the 2nd and 3rd restore boxes are only examples. Yours will be different.
  • Jeffrey Pemberton
    Hi meoloncauli - just to clarify - you don't have your Acer recovery cds ? Your problem is more than likely a corrupt windows file. There's one thing you can always try. Boot up your pc and soon as it's on start tapping the F8 key. This will take you to boot a options menu. Select last known good configuration if it is on the list. Then let it try to load Windows and see what happens. If that doesn't work, or that option wasn't listed, Turn off the pc and wait a few seconds. Reboot and as soon as it's on start tapping the F8 key. This time at the menu select Safe Mode. Let Windows try to boot. If it boots, try to do a system restore. I believe your running Vista so open your start menu search box and type restore.
    You should see a box like this
    Just click on System Restore.
    Then you should see a box like this
    If there's something you installed recently that you think may be causing the problem choose the first option but it sounds like you need the second option. Choose that one.
    Then you should see something like this:
    It should give a list of system checkpoints. Choose one that is a few days before you had any problems. Then follow the prompts and let it do it's thing. It may or may not work but it's worth a shot. Let me know how it turns out please. Thanks.
    Jeff
  • 63 Answers
Get a windows cd and boot to the revovery console, see below or
http://www.grc.com/spinrite.htm download Spinrite on another machine, if it cannot fix it then it will recover your data.
Starting the Windows Recovery Console loadTOCNode(2, 'moreinformation'); To start the Windows Recovery Console, use one of the following methods: • Use the Windows Setup floppy disks or the Windows CD-ROM to start your computer. At the "Welcome to Setup" screen, press F10 or press 'R" to repair. • U
Try:
CHKDSK loadTOCNode(3, 'moreinformation'); chkdsk drive /p /r The chkdsk command checks the specified drive and repairs or recovers the drive if the drive requires it. The command also marks any bad sectors and it recovers readable information.
You can use the following options: /p : Does an exhaustive check of the drive and corrects any errors.
/r : Locates bad sectors and recovers readable information.
The boot records my need fixing:
FIXBOOT loadTOCNode(3, 'moreinformation'); fixboot drive name: Use this command to write the new Windows boot sector code on the system partition. In the command syntax, drive name is the drive letter where the boot sector will be written. This command fixes damage in the Windows boot sector. This command overrides the default setting, which writes to the system boot partition. The fixboot command is supported only on x86-based computers. FIXMBR loadTOCNode(3, 'moreinformation'); fixmbr device name Use this command to repair the MBR of the boot partition. In the command syntax, device name is an optional device name that specifies the device that requires a new MBR. Use this command if a virus has damaged the MBR and Windows cannot start.
Warning This command can damage your partition tables if a virus is present or if a hardware problem exists. If you use this command, you may create inaccessible partitions. We recommend that you run antivirus software before you use this command.
You can obtain the device name from the output of the map command. If you do not specify a device name, the MBR of the boot device is repaired, for example: fixmbr \device\harddisk2 If the fixmbr command detects an invalid or non-standard partition table signature, fixmbr command prompts you for permission before rewriting the MBR. The fixmbr command is supported only on x86-based computers.
Posted on Jul 05, 2008
    Scholar:
  • 135 Answers
Sir,,
i think u got an boot up problem,,only if go into windows we get an interface to solve the prob..
if it cums b4 loaidn the OS..then only way is to use boot cd
thank u
Burning software for the acer aspire 3680 where
A couple of good free burning programs are CDBurnerXP and InfraRecorder. DVDStyler is a good program if you want to try authoring DVDs to play back in regular DVD players. These programs are all free to download and use, full-function, not shareware or demo versions.
Mar 31, 2010 | Acer Aspire 3680 Laptop
I start up my Acer aspire 3680 laptop, all i get is a pale blue screen and nothing else. however if the lid of the laptop is pushed in a certain way the screen works. Is there anything i could possibly do...
there really is no "home remedy" to fixing this problem. the screen needs to be replaced. what you can try is get a small clamp (that doesn't clamp too tight) and put it where it keeps pressure on that spot so its usable. im not sure what size screen you have on your model but it will end up needing to be replaced in the long run. ebay is usually the best place to get them.
heres a link for price ranges if needed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=aspire+3680+screen&_sacat=See-All-Categories
i hope this helps
Nov 30, 2009 | Acer Aspire 3680 Laptop
MY Acre Aspire 3680 is Frozen! Need some Heat- appreciated :)
This one can do to remove the Hard Disk and try to enable it without hard disk.
if the problem is both are still remove the memory and clean it.good luck
Aug 15, 2009 | Acer Aspire 5720-6661 Notebook PC
TRYING TO INSTALL 64 BIT VISTA ON A ACER ASPIRE 3680
Your Aspire 3680 is not 64 bit ready or compatible....sorry
Apr 11, 2009 | Acer Aspire 3680 Laptop
Boggle unlock code
Sorry you'll have to buy the game to get anymore time ,playing this game . I dont encourage people to hack games.
Mar 13, 2009 | Acer Aspire 3680 Laptop
Bloue tooth acer Aspire 3680 not work
could be that your acer aspire 3680 actually doesn't have bluetooth. they use a standard case for most of there laptops. it has the button for bluetooth but it doesn't have the actual bluetooth card or required hardware.
Sep 17, 2008 | Acer Aspire 5050-3242 Notebook
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
218 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
