Question about Kenmore 22422 Top Load Washer
Kenmore washer 24642300
Hi...my kenmore washer fills with water and then stops...never moves on. even if i move the cyle to spin - nothing happens. no draining, no agitation, no spinning. do you have any idea what could be wrong?
my dad checked the fuse box and its not that .
  • Danny Craycraft Dec 22, 2011
    I have the kenmore washer 24642300, i started washing and when i came back it was still full of water? and now it wont do anything at all? whats wrong? and what part do i need?
  • 413 Answers
The lid switch has failed. To replace lid switch;
REMOVE POWER, lift the console by removing the trim on either side. Grasp the top of the trim and pull forward to expose a screw. Remove both screws and lift console.
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The lid switch can now be accessed and replaced.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 05, 2008
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
I filled my washing machine with clothes tonight and it got to the end of the short cold wash cycle and had stopped running so I pushed in the knob then pulled it back out and then pushed it back in and...
It sounds as if the machine doesn't spin during the spin cycle. Normally the agitator stops spinning, fairly quickly, if the lid is opened during the spin cycle.That safety circuit includes a switch mounted under the opening and is set by a tab on the lid that protrudes thru a small hole in the top of the washer. The most likely failure on most Kenmore models is that switch, broken or loose, the tab on the lid broken, or the two misaligned. I would need the model number of your washer, located on a tag on the bottom of the lid to be more specific
Jan 07, 2010 | Kenmore Washing Machines
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
My washer does not spin or move during wash cycle the moter runs but nothing is moving.
Hi, this motor has faulty windings, causing it to lock up and not rotate the drum/basket. replace this motor asap if possible.
May 29, 2009 | Kenmore Washing Machines
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 22422 Top Load Washer Logo
164 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
