Question about 3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk)
VPN or proxy connection
I would like to have all my LAN and Wi-Fi connections to go through the same VPN or proxy.
How do I do this?
Thank you,
Anders
    Problem Solver:
  • 11 Answers
You need to use hub switching to do that, for the service google for WiTopia or utraVPN.fr
Posted on Oct 27, 2009
No Internet can I connect to my neighbours so I can watch Netflix on my play station
Hello Friends,
First of all you are self connect to internet, there are two options you are connect internet.
1> Wi-fi through you connect and Lan cable. connection before you configure Internet IP address, DNS to you laptop, and open wi-fi option. and sec option is cat5 and cat 6 wire through connect.
But all thing available you have like RJ 45 connector, Lan tested, Lan cable, cutter, etc.
My suggestion you contact networking engineer because have all network thing available.
More Technical Support visit and call.
Aug 25, 2013 | Computers & Internet
Panasonic viera tv. Connection error 007
My TV set is PANASONIC VIERA 32AS600 series. Received error 007, canot connect to wi-fi network. In wi-fi settings, change to MANUAL, check proxy settings: delete all letters/characters in proxy address (leave blank), proxy port is not critical. Check your connection. Good luck !
Jul 30, 2012 | Panasonic Televison & Video
Is it possible to get a wireless connection to the vaio PCV-RX221
Vaio PCV-RX221 does not have Wi-Fi capabilities. If you wish to connect it to Wi-fi, you can use a USB Wi-fi LAN Card, which can be connected to any USB port of the PC and can be used to recieve wi-fi signals/ data. Note that PCI Wi-fi LAN Cards are also available, which are internal and added to PCI Port of the PC.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Sony VAIO PCV-RZ221 PC Desktop
IT WILL NOT LET ME CONNECT TO INTERNET BY WI FI OR IF I PLUG IN
is your internet connection working ? Do you have another device at hand to verify this ? also, make sure that in your browser you don't have a proxy enabled (tools->internet options ->connections->lan settings proxy checkbox must be empty)
May 12, 2011 | Computers & Internet
I just got my acer one, when i went for wi-fi at local restaurant, the netbook showed connected but when i clicked on internet explorer it could not connect.
Try going to internet options, then connections, then go to lan settings. Make sure there's no check on use a proxy server.
Oct 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
How configurate this router? I lost the CD with configuration. Please ask me. Mabey in Polish language?:)
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
When you connect vpn router to wireless router set in wi fi lan property as your vpn network range set vpn router ip as gateway ip of wireless router.Then save settings and restart it.
Let me know if you need further assistance.
Thanks for using FixYa.
May 20, 2010 | NetGear WGR614 Wireless Router
I can't seem to get the wifi to work other then when I'm at home when I don't need it how do I get it to work. Please be simple in your answers not too tech savvy but I love this thing already, and have to...
You have configure the wireless connection at that place where you want to get connected. Like you have done at home.
Most of the wireless connection are secure and cannot be accessed.
Thanks
Smith
Sep 11, 2009 | HP iPAQ HX2490 Pocket PC
ITouch connects to safari, but not youtube or app store
it will happen from time to time....it will go away in probably a week or 2
Apr 21, 2009 | Apple iPod touch
I have a htc x 7500 advantage i ve installed a new windows on it after doing that my phone doesn t recive any GSM signal what can i do to fix it? where can i get the software for the phone application?...
You can connect to the Internet through Wi-Fi, GPRS, Dial-up, or Work connections(such as VPN and proxy connections). If you are encountering problems :
.Open the Comm Manager and make sure Flight Mode (or Airplane Mode) is turned off.
.Make sure the connection method settings are correct before accessing the Internet.
.Make sure the connections have been activated (e.g. Bluetooth, Wi-Fi etc.).
Jan 26, 2009 | HTC Advantage X7500 Smartphone
Wi fi connectivity
Refer to
http://www.fixya.com/support/t189947-ipaq_rx_3715_internet_settings
for a potential solution, as someone else had the same problem.
Jul 02, 2007 | HP iPAQ RX3715 Pocket PC
3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk) Logo
211 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
