Question about Yamaha R-V1105 Receiver
R-V1105 Yamaha reciever
My reciever turns itself off after a couple of minutes. Its not hot so thats not it
  • Anonymous Jan 01, 2009
    my R-V1105 turns itself off. I took what looked like the "protector switch" off the "heat fins" to see if it would stop turning itself off (knowing there might be risks) but that did not solve the problem. Even when the room is very cold, it turns itself off, and sometimes very shortly after I turn the unit on.
    I'd like to just "unplug" the heat switch. Would this work?
    Problem Solver:
  • 5 Answers
I've been working on an R-V1105 for a couple days now. The microcontroller in it is quite sensitive to circuit failures.
In my case, I have a ton of bad solder joints on the board containing the voltage regulators and power amp for the surround channels. This is but one of many potential causes of shutdown, but I'll bet, based on my experience with Yamaha, that the problem is a soldering issue.
Posted on Jan 12, 2009
You don't think I have enough problems. I was reaching out to the decent music fans out there that could help me without making a buck on every God Damn thing on this planet. Heres some free advice from a music fan to you, No thanks. That will be $20.00 bucks please.
Posted on Jul 06, 2008
Yamaha RX-V657
This will almost certainly be a problem with the power supply, a faulty part. Unless you have experience of repairs to power supplies, due to the high voltages, I suggest you take it to your local authorised Yamaha Repair Centre.
May 09, 2017 | Yamaha RX-V657 Receiver
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Turns it self off intermittantly and it is not overheating
Check for a speaker short or wire touching, beyond that, it would have to go on a bench for testing. Probably a cold solder joint if not a speaker or wire. Hope this helps
Dec 12, 2009 | Yamaha R-V1105 Receiver
Reciever turns itself off
try cleaning it out, get all the dust out of it if not , you may have some screwed up capacitors or transformer
Jan 02, 2009 | Yamaha RX-V757 Receiver
Shuts itself off randomly
Go to the site http;//www.loadparts.com there got the ICs you need .
May 17, 2008 | Yamaha R-V1105 Receiver
R-V1105 amplifier ICs ASICs
Can you give me the numbers of the IC.
Apr 20, 2008 | Yamaha R-V1105 Receiver
R-V1105 Will not turn on
Change the audio amplifiers ICs because they are damaged,that's why your device protect himself from a bigger damage.Good luck.
Apr 18, 2008 | Yamaha R-V1105 Receiver
R-V1105 Yamaha receiver
Your audio amplifier ICs are damaged,you gotta change it.
Nov 17, 2007 | Yamaha R-V1105 Receiver
Shutting off
Same here... except now it won't turn back on :(
Oct 06, 2007 | Yamaha Audio Players & Recorders
Yamaha R-V1105 Receiver Logo
703 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
