Question about HP Photosmart R707 Digital Camera
Help hi i have an hp photosmart r967 camera. it had been working fine then all of a sudden when i tried to snap a pic it wouldn't, camera said "charging flash"????? the camera was completely charged & i had taken pics just prior to this problem with no issues please help kat
  • fanatic1 Oct 20, 2008
    I have the same flash problem. The camera says charging but will not take pictures. It does not matter how long you hold the flash button.
    Problem Solver:
  • 13 Answers
Charging flash means then the camera is charging the flash light,, thats not a problem,, just wait for a couple of min, , and then take photos,, hope i helped ya
Posted on Oct 19, 2008
SOURCE:
Why wont my HP photosmart R967 turn on battery is new and docking station is fine but it will turn on if connected to docking station
It is likely the battery is not making contact properly or is not getting fully charged.
Check the instructions on battery connection on page 9 and confirm the lights are blinking correctly to show battery is charging.
http://h10032.www1.hp.com/ctg/Manual/c00717663.pdf
Aug 03, 2014 | HP Photosmart R967 10MP Digital Camera,...
My R967 got a little moisture on my last fishing trip to canada, so I took the battery out and memory card and blew it with a blow dryer, it had blue stips in the monitor and I kept it on the charger for a...
actually the moisture must have entered the leads of the display...
the leads should be removed and then it should be dried so take the moisture off..
better take it to a service centre..it is risk to manually operate the sensitive parts inside and you could end up damaging the display
Jun 26, 2008 | Cameras
Spots in the photos (HP Photosmart R967)
Do you see it on the screen as well as on the computer? Then there is something in the camera; dust or debris, and it needs a cleaning. If it is just on the camera screen, there could be a defect on the LCD.
Apr 14, 2014 | Cameras
How do I download pictures from my photosmart R967 camera?
Download & read the User manual photosmart R967 camera instructions @ http://h10032.www1.hp.com/ctg/Manual/c00717663.pdf
Hope it helps.
Mar 30, 2011 | Cameras
Looking for 2 GB memory card for HP camera- R967
The R967 uses standard SD cards. You should be able to purchase them at any department, electronics, or office-supply store. You may also see them at many drugstores and supermarkets.
Dec 15, 2010 | HP R967 Digital Camera
Will an SDHC card work in the HP photosmart R927?
No, it won't work unless HP provides a firmware update. Hp has two websites that mention what type of sd cards are compatible with your camera. One says it is and the other says it isn't. I have a HP R967, which is similar to yours. I bought an HP sdhc card from a HP website that said both our cameras could use it. I own several of this model camera, (I bought 3 to give as gifts) and the sdhc causes the cameras to display 'wrong format.' I suggest calling HP's headquarters and asking them to provide a firmware update similar to the one that HP offered for the HP M537 camera and that Casio offered for their older cameras to let them use this type card, which is what I've been doing.
Sep 29, 2009 | HP Photosmart R927 Digital Camera
HP Photosmart R967 memory card is locked...
I have an HP R927 and just had the same problem. Take out your memory card. Look on the side of the card and you will see and white "knobby thing" ... make sure it is pushed up ... that should fix it.
Sep 12, 2009 | HP Photosmart R927 Digital Camera
Chip says full after few pics
The chip may not be inserted correctly. You can tell by seeing or not seeing SD symbol in the view screen. Try removing the SD card. Go through the memory and see if the pictures were saved to the camera or to the card. If the pictures were saved to the camera, turn off the camera and re-insert the card. See if the cards responds by showing more pictures available for taking and move the pictures to the card. If the pictures were saved to the card, then the card may need to replaced.
Dec 31, 2008 | HP Photosmart R717 Digital Camera
HP Photosmart R707 Digital Camera Logo
195 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
