Question about Sanyo FXCD-500 RB CD/Cassette Receiver with CD Changer Control (Factory Refurbished)
Nothing happens I was able to remove the stuck CD from the audio systemby removing the face plate. I put the face plate back on and then replaced the cover (it is removable to prevent theft). Maybe I got that backwards. I checked the fuse and it is fine. The unit will not turn on. I did not disconnect any electrical. All I did was to remove the CD and reassemble the unit. I have done that twice and it still does not turn on. I have no radio, tape player or CD player working. Nothing lights up to indicate that the unit has turned on. Judi
  • 3 Answers
You have to be more clear with your problems and if they have a problem saying the brand and model your problem may be that some wires were found off the red wire is 12-volt power must be yellow and also has to be 12 volts this is for the lighting of the screen.
Posted on Sep 16, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Judi -
Please see your post titled "Stuck CD" for the information relative to this problem. Thank you.
smartsolve
Posted on Jul 05, 2008
2 Suggested Answers
  • 359 Answers
SOURCE: Sanyo FXCD-500 RB CD/Cassette
Judi -
Please go to your posting titled "Stuck CD" - I am attempting to help you!
smartsolve
How to remove cd stuck in player
Remove cd player and insert small tool to release stuck cd. Otherwise dissassemble cd player and remove.
Take to audio store and have them reome the cd.
Mar 20, 2015 | Jeep 2006 COMMANDER Radio a1z115973...
Code 99, won't Eject cartridge
You need to remove the unit, or at the very least, remove and obstructing front face plates to see if there is a manual release. If not, remove the unit completely and see if you can remove the CD.
Jun 06, 2014 | Car Audio & Video
Cd is stuck in car radio, how do I get it out?
Hi and thank you for using fixya:
Please do the following to remove your cd
1-take out all plastics that prohibit you from pulling your cd changer out.
2-take out your cd changer
3-disconnect gently all cables from the back and mark them so you know how to put them back
4-remove all screws from top of the unit and bottom
5-open case and you should be able to see all cds
6-remove necessary cds
7- put back screws on cover
8-install back in the car and put panels back
good luck
thanks
Jun 22, 2010 | Car Audio & Video
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
Unable to remove cd magazine
The reason for this would most likely be that there is a disc stuck in the cd mech that has not returned to the magazine. It could also be a bad gear or belt, in fact there are a variety of things that can cause this. Unless you have some experience with this, I suggest that you take it to a service center. Ask them what they would charge to remove the magazine only and then return it to you. Sometimes they get stuck for odd reasons that may not happen again. If you ask them to just fix the cd changer, you will pay more for the repair if it only requires getting the magazine out to fix it. Then you can put it back in and see if it will work. Try it first with no disc in it, just in case it gets jammed again you will not have a cd in it. If it cycles thru its intialization process and you can still eject the magazine, there is a good chance it will work for you and then try a disc in it.
Many service centers will remove a stuck magazine for just $25 or so, but if you leave it for a repair you will spend much more even if there is nothing more wrong with it. I have been working in this field for nearly 20 years and have worked at 4 different service centers in that time, and every one of them did the same thing.
If the cd changer still doesn't work, take it back and see if they will apply the amount you have paid towards a repair. Believe me, you do not want to start taking these types of equipment apart if you don't need to. You may never get it back together again working right. They can be a real nightmere.
Nov 06, 2008 | Xtreme Sound Car Audio & Video
2002 ford mustang-cd player says cd error and won't work- cd stuck in it?
MY 2002 GT HAD THIS PROBLEM! ALL YOU HAVE TO DO IS DISCONNECT THE POSSITIVE SIDE OF THE BATTERY FOR A FEW MINUTES AND REATTACH IT. WHEN YOU GET BACK IN THE CAR THE CD WHILLE BE HANG OUT OF THE CD PLAYER! I DON,T KNOW WHAT CAUSES THE PROBLEM, BUT MINE SEEMS TO DO THIS WHEN IT IS HOT OUTSIDE (95 OR HIGHER) WELL I HOPE THIS HELPS SOMEONE!
Oct 20, 2008 | Car Audio & Video
Judi -
smartsolve
Jul 05, 2008 | Sanyo FXCD-500 RB CD/Cassette Receiver...
2002 Ford Escape CD Player Problems
remove raido, remove top cover and face a t-10 4 screws in face remove 4 gold t-10 screws on tape asb. use a pocket screwdriver remove cds 1 at a time by lifting one tray at a time
Oct 24, 2007 | Car Audio & Video
Sanyo FXCD-500 RB CD/Cassette Receiver with CD Changer Control (Factory Refurbished) Logo
166 people viewed this question
Top Sanyo Car Audio & Video Experts
Colin Stickland
Colin Stickland
xxxxxx xxx
Are you a Sanyo Car Audio and Video Expert? Answer questions, earn points and help others
