Question about Sony KP-57WS510 57" Rear Projection HDTV
Convergence i change the 2 convergence on my sonytv model#kp57ws510 but i still have red curve on my screen i can't adjust the red convergence if is some resistor i have to change i dont know were is at
  • Anonymous Jul 28, 2008
    Where can I purchase the convergence onsonytv model#kp57ws510 and what is price?
    Thanks,
    YS
  • Sony Master
  • 8,617 Answers
There are a series of 4.7 ohm 1/2 watt resistors all in a row under the fins of the ICs. Check them they have to have one side unsolderd to check them. There are also 6 yellow pico fuses in that line of resistors that need to be checked as well.
Posted on Jul 05, 2008
Curved horizontal green lines bout 2 inches apart from bottom to top of screen.kp-46wt500 model
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 14, 2010 | Sony KP-46WT500 46" Rear Projection...
When we try to adjust red cross, red adjustment will go side to side but not up and down. Red horizontal line is curved instead of a straight horizontal line. Blue can be adjusted up and down and don't...
Thats the classic sign of failed convergence ICs and resistors. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the parts and the Cd with instructions.
Mar 09, 2010 | JVC AV-48WP30 48" Rear Projection...
Screen distortion
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 17, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Cloud like image around edges of screen
  • Screen looks 3D
Apr 04, 2009 | Philips 60PP9352 60" Rear Projection...
Shadow images and scrolling banner curves upward and back down.
  • Screen looks 3D
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Sony kp57ws510
you need to replace both convergence ICs they are STK392-560 and you will also need a couple 3.5amp pico fuses and a couple 4.7 ohm 1/2watt resistors. You can get replacement parts at the following link and they provide free instalation instructions and free online tech support to help you with the instalation process. Heres the link.
http://servicemanuals.vstore.ca/
Aug 07, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Picture looks curved (concave curve) on my sony KP-46WT510
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
May 21, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Curved red lies at top/bottom with some double vision in lines
This is from another fixya article but its relevant to your problem.
  • Screen looks 3D
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Apr 25, 2008 | Samsung HCM5525W 55" Rear Projection...
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Sony KP-57WS510 57" Rear Projection HDTV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
