Question about Texas Instruments TI-5006 II Calculator
Error message E is permanently displayed and the keypad does not work except for the ON/C button. How do I resolve this
I fixed this exact problem on my TI-5006 II calculator by simply replacing a "dead" battery. Three of the four battery's were good (after cleaning their terminals) but the fourth was completely bad (i.e. read "Replace" on my Battery Tester). Other problems probably can cause this exact same error message but this cure was simple and cheap. The problem first appeared after the calculator was dropped. A sudden shock (dropping it) can cause even a good battery to fail.
Posted on Mar 12, 2009
Error message: Stat Calculation How to resolve
I am sorry, there is not enough information (not to say no information) about what you were doing to try to guess what might have gone wrong.
Sep 20, 2013 | Casio ClassPad 330 Graphing Calculator
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
Aug 22, 2012 | Texas Instruments TI-81 Calculator
Ti-nspire with 84 keypad problems
It seems to me that you get the loading bar when you switch keypads. I just switched keypads, and when I reinserted the TI84 Plus keypad back again I found my last TI84 Plus screen contents still displayed.
As to the RAM cleared message, it probably is related to the batteries being depleted.
To verify battery charge level, you may use TI connect.
Mar 31, 2012 | Texas Instruments TI-Nspire Graphic...
Calculator error message says nonreal ans
Apparently your problem has a complex (non-real) answer. By default the calculator works with real numbers and gives this message when the solution is not real.
You can change this by pressing the MODE button, down-arrow to the "REAL" line, right-arrow to one of the two complex display modes, then press ENTER and 2nd QUIT to save the change.
If you still have problems, could you post an example that produces this message?
Dec 13, 2011 | Texas Instruments TI-83 Plus Calculator
Clearing or correcting an error message on the TI-83 Plus
Press [STAT] to open the Statistics editor. From the menu that displays, select PlotsOFF and press [ENTER] twice. The calculator answers "Done".
Open the [Y=] editor to enter the functions to be drawn. Use the Trace ONLY after the graph has been displayed.
To clear any message without necessarily removing the conditions that yield the error press the CLEAR button.
Apr 13, 2010 | Texas Instruments TI-83 Plus Calculator
Why am I getting error 14 with all the functions under the stat button on my ti-86 calculator? I know I'm entering the right information, but it won't work...
The software for your calculator may need to be updated. You can get the update from the manufacture's website under the download or support tab.
Nov 16, 2009 | Texas Instruments TI-86 Calculator
HP 15c Passes self test but screen flashes - wont turn off
You can get rid of the flashing (usually due to memory overflow) by pressing [<-- left arrow] [ON] or [g] [CF] 9.
If you want to reset permanent memory
1.Press and hold [ON] then press [-]
2. release the [ON] key, then the [-] key.
Screen displays Pr Error.
Press any key to clear display.
Hope it helps.
Sep 25, 2009 | HP 12c Calculator
Loading Screen Freeze
  1. Remove the keypad (for TI-Nspire) or the battery door (forTI-Nspire CAS) and remove at least 1 battery from each column ofbatteries. After 2-5 seconds, reinsert the batteries and turn the uniton. This will cause the unit to reboot the operating system.
  2. Holddown [Home] [Enter] [P], and while holding these keys, press [On]. Thedevice will boot up as in the previous reset, but will display a menuwith the following options. Please try options 2, 3, and 4 in thatorder.
    1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
    Note: TI-Nspire family model options 2 and 4 above require that the OS be reinstalled. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
Dec 21, 2008 | Texas Instruments TI-Nspire Graphic...
Won't boot into new screen
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Hold down [Home] [Enter] [P], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
Nov 22, 2008 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-5006 II Calculator Logo
191 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
