Question about GE JVM1850 1000 Watts Microwave Oven
GE Microware Hood SpaceMaker Problem
The microwave fun turns on automatically. sometimes a beeping sound is displayed with Message F3 on the display panel. We now to have to keep it unplugged from the mains. Sometimes we may use it briefly with success most times on plugging it back in the buttons on the display do not work. This is the model number :JVM1850SH06 What could be wrong?
    Problem Solver:
  • 4 Answers
I would try the Control Board or PCB, it seems like some kind of electrical malfunction.
Posted on Nov 11, 2008
My microwave GE oven will not operate properly when I try and use 7-8-9 on the controls. I checked the manual and it didn't say anything about this problem. Does anyone have a solution? Everything else seems to be working fine with the exception of the above mentioned numbers.
I have a Model #JVM1850SH06 Stainless GE Microwave.
Posted on Oct 24, 2008
  • GE Master
  • 9,098 Answers
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker profile ge over the range microwave displays f3 and buttons will not do anything.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 22, 2010 | GE Profile Spacemaker Over-the-Range...
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
zayd4@aol.com
Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave f3 code
You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/model-display.php
If you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
Sep 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is beeping with F3
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
147 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
