Hello
Dryer will not turn on.
Door working and closing fine. The door switch makes slight clicking sound when operated by hand I assume that means it is engaging.
electric coming in is good and connectors to dryer are intact.
The light is on.
Thank you
Dan
My name is Peter. I am a retired field service appliance technician.
I can not help you very much because you did not post a model number. The model number is located on a label when you open the dryer door.
The dryer will not run it you have a bad door contact switch. The clicking sound may be your door switch engaging. Open the dryer door and push on the button on the face of your dryer. If it clicks then the door switch is good.
So, then you have either a blown thermal fuse, operating switch or a bad high temperature switch. These components are about $25.00 - $30.00 each. Only one of these components are bad. They are easy to replace.
So, since I do not have your model number that is all I can not tell you how to check or replace them. I assume you have an electric dryer.
Assuming door seal is good, make sure there is nothing "caught" under the seal that prevents the door from closing properly. Otherwise, look for anything else that would contribute to that issue. Possibly the door switch that turns on the interior light and acts as a safety for a door open situation may not be operating properly. See my "generic" tip for "buzzing" dryer issues.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Power switch? Do you mean push to start switch? To see if you have a bad push to start 1st unplug. Open back top panel. Only do this test if you hae two wires going to the push to start switch. Wear gloves so you dont kill yourself. seriously. If you do have two wire then disconnect from push to start. Make sure they are not touching anything!!! Plug machine in. Tunr timer to 60 minutes. Touch wire together then pull apart. If machine kick on replace push to start. If not put everything back the way it was. Jump out door switch. If door switch is jump and still dont work then check motor test. Check harness on motor. If has a capacitor need to check with a cap. tester. You need a service manual to test wheather you have a bad motor. The manual will show you how to properly test a motor (each lead has ohms valve and you have to know what they are to test)
if the door is not tight as in you can move it slightly when its closed,the door strike and door catch need replacing and can be done without dryer disassembly at the front door,open the dryer door and in the lower right hand corner theres a small plunger switch push this in with your finger you will hear a click,then start dryer with door open being careful,this test will rule out switch problem,then just replace door parts
Sounds like the motor is gone. Try opening the door and pushing the door swithch inside the dryer door cavity.This may take two people but while holding the door switch, push the start switch and turn the dryer drum at the same time.(in a clock direction) If the dryer starts it means the moter is shot.
assuming that the circuit breaker or fuse is not blown, this is most likely caused by the door switch. if the door is not closed, the dryer will not turn on, period. you will have to try to jump over the 'possibly bad' switch. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. use a piece of wire to connect them or just tape the metal ends together. this will bypass the door switch. make sure all metal parts of the wires are covered to prevent a short on the metal walls. be sure the now loose wires will not get caught on anything, like a rotating drum. close the lid most of the way. turn on the breaker and try to operate the dryer. if it now works, replace the door switch. be careful, opening the door will not shut off the dryer now. good luck
