I have a GSA DVD Rewriter and a Dell 600D laptop. The connector on the USB cable will not, nor can it insert into the computer as it is an unmatched connection. Can you help me with this problem?
    Master:
  • 638 Answers
Send the brief description of your unit through picture
Posted on Jul 05, 2008
    Guru:
  • 1,894 Answers
Is it a smaller version like used for motorola USB cables??
or a normal version??
  • dewan nafees ahmed Jul 05, 2008
    can you please upload a picture of the USB connector of ur computer and the cable of the writer?
Can I put internal LG GH22 rewriter inside external GSA-E60N
First, open the external casing.
You'll find an "internal" CD/DVD drive, connected to an adapter, and the adapter connects to the USB cable.
Now, look at the adapter -- it could be a "parallel-ATA" interface, or it could be a "SATA" interface. The new CD/DVD drive will have to have the same connectors (data and power) as the adapter.
You might have to exchange the SATA device for a Parallel-ATA device.
If you have a parallel-ATA CD/DVD drive, look at the back of it.
There is a tiny jumper, and a few labelled settings:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the jumper to the 'MA' setting, so that the USB-adapter will recognize the CD/DVD drive.
Connect the drive to the adapter.
Close the case.
You're good to go!
Jul 22, 2010 | LG Dvd Rewriter Gsa-e60n 20x Ext Black...
Laptop doesn't recognise DVD rewriter - LG
If your laptop dont recognise dvd rewriter it may be due to many reason it may either due to Ide cable or a registry issue or a hardware issue .Try following steps :
1 make sure you have correctly inserted the IDE and Power Cables. Fault of putting the IDE cable in the wrong way around make this happen.
2 Make one drive the the Master and the other the Slave, don't set both to Cable Select.
Is it not recognizing the drives in the BIOS or Windows? Try changing IDE cables?
If BIOS, have you gone into the BIOS and verified that the drives are detected? Try changing the BIOS settings for the IDE Channels from AUTO to CD_ROM. At least then, from a hardware viewpoint, you are forcing the system to recognize.
3 If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players.
4 If its a registry issue then try following steps but remember first take back up of your registry
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters....
RESTART YOUR COMPUTER THEN THERE YA GO!!!! HOPE THIS HELPS
Mar 24, 2010 | Computers & Internet
Hi, I've got an LG super external dvd rewriter gsa e60n that wont power up, any one got any ideas before i throw it out the window?
check your cable. no need to throw it. If there is any problem you can repair at service center.
Regards
Ashly
Feb 02, 2010 | LG Dvd Rewriter Gsa-e60n 20x Ext Black...
My LG GSA-H55L super multi DVD rewriter seems to suddenly have a problem recognising disc. I am using the same discs as before (same batch) but now it always tells me no disc.
have you tried a cleaning disk?if not get some cleaning alchol wipe the disk leave a little on it not much,insert the disk ,this might clean the lense.
Sep 11, 2009 | LG 20x8x20 GSA-H55L Super-Multi Disk...
Nero cannot burn DVD inserted in my LG GSA-H55N DVD-RAM rewriter
Have you tried other discs, or just that one? It might be that the disc you've inserted already has something written on it, and you can't burn a DVD-R twice. From the error message you're getting, that would be my guess.
Aug 10, 2009 | LG GSA-H55N DVD-RAM Burner
My rewriter does not have a drive
Change your jumper to slave if it is on master.
Aug 01, 2009 | LG Dvd Rewriter Gsa-e60n 20x Ext Black...
Hitachi-LG DVD Rewriter for DELL Dimension 2400
Hello jpptalbot.
You can install the CDRW on a free IDE channel (which is not being used by any devices) and there is no need of using a jumper in this case.
Oct 09, 2008 | Dell DVD-ROM for Dimension (6t903)...
I have a GSA-2166D and a Dell 600D laptop.The USB cable from the burner will not insert into my computer. I believe the USB from the burner is a 2.0 Can you instruct me as to what I will have to do to make...
From the research I have done on your dvd model number, the usb cable used is a 2.0 and your dell600D has 2x hi speed 4 pin usb ports type A. You should be able to find an adapter piece to fix this problem. Since this is a dell you might want to call them to see if they sell these types of adapters. Dell is a proprietary system and they custom make their own components and systems, which makes finding components from another source difficult. It will take some digging around, but you should be able to find the adapter. Let me know if this helps or if you need further assistance. Thanks
Jul 05, 2008 | Televison & Video
Can't write DVD's on LG GSA-H42N rewriter
hi ruthgirl
plz disable system restor and do a full virus scan by updating your anti-viruses in safe mode.
Then reinstall the burning software.
Plz feel free to write about your findings
Apr 02, 2008 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
