Lexmark X3690: 4438 002 printer
http://elotusland.com/product_details.asp?dept_id=264&pf_id=KA01LEXMARK-18C1960 Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays! Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Turn the Lexmark printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps.
Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you've completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
1. Look at the indicator light on your Lexmark printer.
You'll need to replace ink cartridges when the light flashes or turns red
instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand
name or purchase a generic version that is compatible with your printer. You
can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the
sides of the Lexmark ink cartridges and pull it out. Dispose of the ink
cartridges in a recycle program like the one at Staples or save the cartridges
for refill.
4. Install the new ink cartridges after removing the
protective tabs. Avoid touching the IC chip when installing the new Lexmark ink
cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print
several pages with the new ink cartridges to make sure you installed the ink
cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
