Question about Microsoft Windows Vista Ultimate Edition
Media Center file types
Hello, I have an hp m8100y media center pc with windows vista ultimate installed on it. Media center, which comes with ultimate, does not recognize any of my pictures. It will see the folder that they are in, but not the pictures themselves. I am not sure, but I think it might be the fact that all of the pictures' file extensions are uppercase (.JPG). Now, help and support within ultimate informs me that it supports .jpg and .jpeg. I am wondering if the difference between uppercase (.JPG) and lowercase (.jpg) would be enough for the media center to not recognize it.
Thanks in advance.
    Novelist:
    Scholar:
  • 160 Answers
Try to rename one of the pictures to lower case .jpg. Normally this isn't an issue, since Windows is not case sensitive on file names. Somewhere along the way you may have changed the association.
Another thing to try is to right click on a JPG file and select Open With / Choose Program. Select the picture viewer of your choice and select Always Use. That should set the association permanently.
Posted on Jul 16, 2008
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Picture of hp m8100y mother board sata and cd rom cable
see this webpage
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c01077641&lc=en&jumpid=reg_r1002_usen_c-001_title_r0001
I have also attached an image of both ends of a SATA data cable (right angled at one end, straight and all types available) . SATA cables are standard, there isn't a special one for any particular device or motherboard.
12.April.20013 c032f163-3941-4529-9272-f7e3110a5dfc.jpg bbe12c09-6d51-471a-bb0c-effac1df97cc.jpg
Dec 03, 2012 | HP Pavilion Media Center m8100y PC, Intel...
Sony VAIO VGC-RB38G PC Desktop needs the media center re-installed
I would seriously doubt that your kids know how to remove Media Center. Maybe they just removed the icon from the desktop. Click Start/My Computer and open the Local Disk C. Look for the Programs File Folder. If you are using Windows 7 or Windows Vista there might be two Program File folders (Program Files and Program Files (x86). Look thru the program files folders for the Windows Media Player Folder or Windows Media Center Folder. Open the folder and look for the Media Player. When you see the Icon you can Right Click on it and select Properties. If the Type of File in the properties windows says Application, that is probably the program that runs. You can close the properties window and double click on the icon and see if it runs.
If it runs, you can close it and go back into the folder and Right Click on the icon and select the option Sent To then select Desktop (create Short Cut). Right Click on it again and select option to Pin To Start Menu.
If you just want to download and install it again.
Get onlineand got to www.google.com In the google search box type: "Download Media Player" or "Download Media Center" (without the quotes). Select a site from Microsoft that will download and install it.
Apr 30, 2012 | Computers & Internet
Need the window media center re-installed
Apr 30, 2012 | Sony VAIO VGC-RB38G PC Desktop
Flicker every 60 sec in Win Media Center TV mode
go to HP.com and look for the TV tuner upgrade. See if that solves your problem. Let me know
Thx
Aug 01, 2009 | Microsoft Windows XP Media Center Edition...
Yes, file extensions, .gif, .bitmap, .jpg are case sensitive. Just like if you tried to save a word document as .DOC then the file would look like test.DOC.doc. Change case and it will be fine.
Mar 02, 2009 | Microsoft Windows Vista Home Premium with...
How can i play AVI files on my media center/player on vista
Windows Vista Media Center won’t play Xvid and Avi files, even if Windows Media Player will play these files. If you want to add support for third party codecs including Xvid and Avi files in Vista Media Center then you need to install the media control plugin for Windows Vista Media Center.
To install the Codec please click on the below link or copy the URL and paste it in your web browser..
http://damienbt.free.fr/index.php#download
This plugin allows Windows Vista Media Center to utilize te FFDShow decoder, which needs to be installed seperately ((FFDShow rev 1108 recommended: download the last version from http://sourceforge.net/projects/ffdshow-tryout)) FFDShow adds support to Vista for MPEG-4 video formats like DivX, Xvid, H.264 and also alllows MP3, AAC, Dolby AC3, and OGG Vorbis audio files to be played back.
have any other queries, please let me know..
Thank you.....
Oct 13, 2008 | Computers & Internet
I have C7180 All-In-One printer, connected to Pavilion Media Center CPU, m8100y, w/ Vista Home Premium Edition X32. The printer no longer recognizes Toshiba digital camera chip. Printer works OK, but COPY...
Hello there.
First of all i would try a newer version of the drivers as you are using Windows Vista. Please click here and download the 'HP Photosmart Full Feature Software and Drivers". While this is quite a big download, it contains the necessary drivers and software for use on Vista.
Please try this and if you still cannot COPY, get back to us.
Hope this helps.
May 18, 2008 | HP Office Equipment & Supplies
Cant able to open windows media center and quick play from the remote control
Hello!
the ultimate solution of your problem is to reinstall the windows operating system of your system. I am sure this will resolve the issues.
After install installing the OS, you should install all the drivers.
May this help!
best regards, melnavz
Mar 02, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Pc will not see tuner
no but that is way to low in vista need leats 2 gb ok
Feb 11, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
89 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
