Question about Kenmore 22422 Top Load Washer
Washer fills with water and never moves on with the cycle...no agitation no anything! any ideas?
Washer fills normally and stops but then thats it...no agitation or washing occurs after. any ideas?
    Genius:
  • 1,224 Answers
this part is broken 3 dollars replace this
this is called direct drive to keep from blowing other things out like tranny or motor before this it use break the whole machine now this little part saves lots of money in repairs these wear out normally
Posted on Jul 07, 2008
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Fill cycle stops before full
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 03, 2010 | Kenmore Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Fills with water and that's it
    ck the water pump, only if it agitates but doesnt drain. If it completely stops after filling, ck lid switch(should here clicking noise from sw.)
    Oct 21, 2008 | Frigidaire FEX831CS Top Load Stacked...
    Agitator not working 90 series model # 11026912691
    Hello aksward,
    Welcome to Fixya.
    Here are some suggestions for any Kenmore washers
    Let me know how it goes. I'm still thinking and searching my repair manuals!
    Huuum
    Please remember to leave a rating!
    KENMORE ELITE TOP LOAD
    Washer stops, won't fill, rinse or agitate
    • Check the following:
    Is the power cord plugged into a grounded 3 prong outlet?
    Is the indicator on the Cycle Control knob properly lined up
    with a cycle? Turn the Cycle Control knob to the right slightly
    and pull to start.
    Are the water inlet valve screens clogged?
    Are both the hot and cold water faucets turned on?
    Is the water inlet hose kinked?
    • Does the water level seem too low, or does the washer
    appear to not fill completely? The top of the agitator is
    much higher than the highest water level. This is normal and
    necessary for clothes to move freely.
    • Has a fuse blown or is the circuit breaker open? If problem
    continues, call an electrician.
    • Are you using an extension cord? Do not use an extension
    cord.
    • Is the washer in a normal pause in the cycle? The washer
    pauses for about 2 minutes during certain cycles. Allow the
    cycle to continue. Some cycles feature periods of agitation
    and soak.
    • Is the washer overloaded? Wash smaller loads.
    • Is the lid open? The lid must be closed during operation.
    Washer will not agitate or spin with the lid open.
    Oct 06, 2008 | Kenmore 22422 Top Load Washer
    Will only work on cycle, will not agitate in the other cycles
    Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
    Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Kenmore Elite Calypso washer won't fill with water!
    i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
    Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
    Kenmore 22422 Top Load Washer Logo
    Sal De
    fordexpert
    Robert Rankin
