Question about Dryers
Fridiaire dryer not turning on
I have a 2 yr old Fridiaire Dryer, model # Fridiaire FERB7800DSO (which doesn't come up on any search engine by the way??).
I cleaned out the lint trap the other day in the middle of a load (force of habit) and the dryer has not turned on since then. I have removed the front lint trap and completely cleaned it out. Still won't turn on. When we turn the start knob it's just a quiet noise like there is something not connecting electrically. I have removed the back wiring panel just to make sure everything is still connected and has good contact with it's counter part.
Any other ideas?
  • kbrug3 Jul 05, 2008
    thanks. Any ideas on how to remove that front and top panel? I've looked online and everything says to remove the kick panel and screws. I don't see a kick plate or screws. Just the front panel (all one piece). I can see a ton of screws on the back... do I dare mess with those?
  • kbrug3 Aug 01, 2008
    re: 2yr old Frigidaire issue ~
    I got the top off of dryer and the belt is fine.The drum can move around just fine. I got out my OHM reader and tested the Thermal Limiter and a few other electrical parts, and there is current running through them. Any suggestions on what I can try next? it's getting pretty sad going to the laundry-mat when there is a 6 mos old learning to eat solid foods in the house! ~:)
    thank you for any suggestions...
    Scholar:
  • 170 Answers
Your drive belt is broke. remove the front panel and then the top panel and you will see there is no belt around the drum.
Posted on Jul 05, 2008
  • Kirk Severs
    Kirk Severs Jul 06, 2008
    If you don't have a kick plate, see how the front panel is attached. Maybe it will come off all in one piece, then you can get the top panel up to access the drum. I'm not sure if it would hurt anything to remove the back, but from what i've experienced the top panel is attached to the top of the front panel and those two panels need to be moved to replace the belt.
My fridiaire refrigerator and freezer model # frt21lr7ab6 the freezer works fine but refriderator will not get cold.
check if you see any ice or frost on the back wall of the freezer that might block the air circelation to the fridge
Sep 02, 2011 | Frigidaire Refrigerators
Our Frigidaire Dryer Model FERB7800DSO turns but doesn't heat. I checked the breaker and turned it off and back on with no fix. I see where some say it could be a clogged vent, bad thermostat, or...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 05, 2011 | Dryers
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Young dryer quits in mid cycle.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 05, 2010 | Estate EED4300TQ Electric Dryer
Where is Fridgidaire serial number -air conditioner
If you remove the outer cover and look inside there should be sticker with the serial # on it
Jan 29, 2010 | Frigidaire FAL126L1A Air Conditioner
Frigidaire Washer/Dryer flse60rgs1 Starts filling but won't stop no matter what setting its put on it just fills the tub, and ultimately overflows
The problem is most likely the float switch or it could be a stuck fill valve. If it is the fill valve, it will stop filling if you unplug the machine.
You can find the parts and diagrams at partselect.com
If you need more help, post a comment.
Thanks,
Tim
May 14, 2009 | Kenmore 22642 Top Load Washer
I have a side by side Fridiaire FRS6R5ESB. I came
I solved my own problem. Just realized the red & green dots are not lights
The only LIGHT is the top signal light marked " water filter." which is green
when filter is ok & turns red when filter needs changing. The red & green
dots are not lights but are indicators for the water filter light. Red dot meaning
"change filter" and the Green dot means "filter ok"
May 01, 2009 | Frigidaire FRS6R5EMB Side by Side...
Dryer won't start
check door switch..onthejob
Jan 27, 2009 | Crosley CDE6000 Electric Dryer
Fridiaire dryer not turning on (another ??)
Yes, I had the same issue. If I slam the door shut very hard then it would work. So I found the issue is the door safety switch not turning on when the door is closed. Simple fix is to put some masking or duct tape on the door so that it would push the switch when the door shuts. There is an indentation in the door in the top left corner where the door contacts the switch. This causes the door to not turn the safety switch on when closed. Simply fill in the indentation with a little tape and problem solved.
Jul 05, 2008 | Dryers
Kenmore dryer king size capacity 90 series
Sorry to say, but the motor needs to be replaced. motor cost around $150... 9yrs old=not worth fixing...
Jan 03, 2008 | Kenmore 63942 Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
