Question about Sony KP-51HW40 51" Rear Projection Television
Red & Green ghosting on one side
It looks like I need the convergence IC's. I have red and green out of alignment on the left side of my TV (from the center all the way to the left edge) Would this mean one of my Convergence IC's went out? If tis is the problem should I replace both of them while I'm in there?
Thanks
  • vanh1 Jul 25, 2008
    I think this is the same problem. My left side tv is burry with red, blue, green colors visions/lines and the other side double vision. I don't know the model number but it's a 51" Sony.
    Sergeant:
    Champion:
  • 250 Answers
More than likely yes you've had an IC go out. I would replace both. It never hurts, and if one has gone out the other will eventually follow. IC's are cheap and who wants to do it twice. :)
Posted on Jul 07, 2008
  • 346 Answers
SOURCE: Convergence problem
replace the ics
Posted on Nov 24, 2007
  • 11 Answers
SOURCE: convergence problem
One or both of the convergence IC's are bad and has blown one or both of the fuses. Pull off the front speaker grill and remove the cover, loosen 2 brass scews holding the aluminum frame work, lift it up and out. Inspect The convergence IC's and the soldered connections to the board, check the fuses on the board. Replace both IC's and the fuses.
Posted on Nov 27, 2007
  • 1030 Answers
SOURCE: Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Posted on Jan 15, 2008
ctf1800
  • 4402 Answers
SOURCE: JVC 56wp30 convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Posted on Jan 31, 2008
daniel719
  • 240 Answers
SOURCE: Need to do a convergence alignment on RCA rear projection unit.
replace convergence amp board.
this is a RCA tompson part number, you can find it on line the part number is.
#264103
regards,
daniel.
PS thier are manny ways to repair your board and manny parts to look at its much less time consuming to just replace the board.
Posted on Jan 12, 2009
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
I have green outlines on the screen
YOU NEED TO REPLACE THE CONVERGENCE OUTPUT I.C.
Dec 26, 2009 | Samsung HCM4215W 42" Rear Projection...
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red horizonal convergence tilts instead of adjusting evenly.
For your hitachi unit one of the convergence IC is bad along with couple of low value resistance on
the convrgence board.
Good luck
Dals123
Oct 09, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
Oct 30, 2007 | Mitsubishi VS-45609 TV
Hitachi 50" - 50GX30B
You will need to replace the convergence IC inside the TV set.
Aug 12, 2007 | Hitachi 50GX30B 50". Rear Projection...
Red and green lamps look off center
Intermittant convergence alignment issues are quite common.
Either solder the convergence IC pins or better yet , change out
the IC's with first quality OEM spec or upgrade..............T.
May 07, 2007 | Mitsubishi WT-42315 42" TV
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
