Question about EliteGroup P4VMM2 Motherboard
MOTHERBOARD PROBLEM i have AMD machine twice. for the 1st one i cleaned the board with a soft brush. after that the it does not come on on the monitor. nothing is displayed. i have done everything i could but to no avail for the second one (k7vmm) i replaced the processor with the first one and all i could see was smoke. after taking it out i allowed to cool for 3 hours but till now nothing is working nor responding. i am really pissed off. both a.m.d machines have spoilt. i dont know what to do now. pls help me. very fast. thank u
Inee the jumper settings for front usb ports
Posted on Nov 03, 2008
  • 63 Answers
You have broken both - time for a new machine or rebuild a machine with the working parts you have left but with a new mobo.
Posted on Jul 05, 2008
How do I clean the bobbin housing from all the fluff
A soft brush like a makeup brush will clear out the excess fluff. Remove bobbin case first. Or a can of pressurised air as used on computers.
Jun 07, 2015 | Sewing Machines
Acer Aspire One D257 - 13450 Will not come on. It takes a full charge, but when you push the power button absolutely nothing happens. Would this be the mother board?
check hard disk and/or ram if connected properly. Clean the motherboard (do it crefully) with soft brush. Check cmos battery voltage, a button cell on motherboard, it should be around 3 volts, if that doesnt fix, you will have to take it to its service centre. Thank you
Mar 27, 2014 | Acer Aspire One PC Notebook
Memory not working
The 2nd RAM module could be incompatible with the 1st RAM module or it maybe faulty.
Try using the same make and speed as the 1st RAM module.
Mar 10, 2013 | EliteGroup ECS A740GM-M Value Socket...
My ecs G31T-M motherboard goes on but not my display what can the problem be.
If you have a built in video card, I suggest you clean the connection of your memory card, you can use a pencil eraser to clean the contacts and with a soft brush clean the inside of the slots, insert back the cards and power on your machine. If did not help, try to insert a video card in the slot and power the machine on, if it works your problem is solved. If none helped I suggest you buy a new board.
Sep 03, 2011 | EliteGroup ECS G31T-M Motherboard - Quad...
Can you tell me why when i put CPU in my computer he give error? CPU is AMD Athlon 64 3400+ 2.4GHz socket 754.My motherboard is socket 754 Gigabyte GA-K8NE-RH. Problem is my computer or CPU?I take CPU...
The motherboard will support this CPU, with the F1 bios.
I can only advise, that IF your motherboard was working ok before you put the new CPU in, it must be the new cpu you bought.
If this is the 1st CPU you have tried, there is a chance the board is damaged
Jun 13, 2011 | AMD Athlon 64 3400+, 2.4 GHz...
Maximus motherboard with intel x38 chipset won't boot
There's a chance of overclocking, ram failure, bios failure, cpu overheat, power supply problem,etc.. But in the first step, remove everything which are inserted on the board, like power cables, processor, rams, bios battery, Pci cards, sound cards, etc.. and clean them using soft brush, also clean the mother board, there might be dust clogging the chipsets like resistors, transistors and capacitors, and reinsert everything after cleaning... I hope this will help if there's only a small problem except circuit short... Good luck...
May 06, 2010 | ASUS Maximus Formula Motherboard - 45nm...
Motherboard 8kra2+
This motherboard uses a style called Socket A. Socket A has 453 pins, so yes it will work with the processor you are wanting to use with this motherboard. Also, this is an AMD board, so getting an Intel CPU won't work, must get a AMD processor with this machine. Hope this helps!
Jan 01, 2010 | EPoX EP-8KRA2+ Motherboard
CLEANING of MotherBoards
Just use a small soft brush and a hoover to catch the dust while you are gently sweeping the notherboard. Do not use liquids !!!!!!
Good luck
Jan 31, 2009 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
76 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
