Question about Mpio Audio Players & Recorders
Hmm...well wnhen ever i charge my mp3 and i connect the usb with my computer then it doesn't show up anything in ma computer itz connected ornot n thats why i can't put new songs in it..
  • Patrick McGee
    Patrick McGee May 11, 2010
    What version of windows are your running? Or is it a Mac?
  • 8,596 Answers
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
Hi. i am tryinmg to charge my nieces mp3 that she has got. she lost the original chatger (lead) so i am using a spare one that i have found.. its coming up on the screen connected but its not showing the...
Hi, why it's not charging yet ,i think its not yet recognizing the mp3 player yet. You will need to follow the below step and solve the problem.,Then after trying out this steps and still does not work,That means you will need to replace the USB cable...
Hi, when an m3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Good luck......
Mar 12, 2011 | Audio Players & Recorders
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Dec 21, 2010 | Sony Walkman NWZ-E344 Digital Media Player
My Samsung YP-T9 MP3 Player wont turn on!!
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
Oct 18, 2009 | Samsung Yepp YP-T9 Digital Media Player
MY MP3 WONt w0Rk!!!
try searching on my computer and it should say something, if it does, then that means it is connected
Jul 03, 2009 | iLO (2 GB) MP3 Player
WALKMAN NWZ-B135F crash or freezes when formated
ooh sorry about that i had the same problem with my samsung usb style mp3 player the problem is the usb has been fiddled with and wires have come loose you'll probably need to replace it sorry...
Jun 01, 2009 | Sony Walkman NWZ-B135 MP3 Player
Connecting mp3 player to old computer without recharging outlet
To my knowledge, the only way to charge an mp3 on a computer is with a USB drive, so if the computer is so old it doesn't have USB ports, then you may want to look into buying a new computer or asking a friend to borrow theirs.
Jun 01, 2009 | SanDisk Sansa Clip MP3 Player
Nextar MA 166 MP3 Won't Charge
You have to install the software for the mp3 player BEFORE connecting the mp3 player to the computer, or else Windows XP will override the native drivers. That particular Nextar is not compatible with Windows Vista, so you may have a problem if you have a newer computer.
-Tha Mp3 Doctor
Jan 24, 2009 | GPX ML648B MP3 Player
My Creative Zen Stone Plus is not Charging completely
Use USB 2.0 Port.. My charging status was stuck at 21% till i swapped to USB2 port.. I've tested it and it works..
Regards,
Arvinderan Ganason (Malaysia)
arvinderan@gmail.com
Jan 17, 2009 | Creative Labs ZEN V Plus MP3 Player
89 people viewed this question
Top Mpio Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
David Roberts
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
