Question about RCA D52W135D 52 in. TV/DVD Combo
Rca d52w14 Hello and thanks in addvance tv coler was flikering then turned purple now just shows red then shuts off was wondering if it sounds like a fly back circut? thanks rich g
  • 1 more comment
  • Anonymous Aug 25, 2008
    I have a rca d52w14 hdtv,,it flickers when we first turn it on then eventually it will warm up and work......then sometimes when it goes to commercial or switch channels it will flicker again and we have to change channels or turn it off and on to get it to stop flickering,,
    we have a d52w14 hdtv..it flickers when you first turn it on. eventually it will begin working, then it will start flickering again, mostly if a commercial comes on or different channel, we have to change channels or tunr it off and on again to stop it from flickering.
  • bonham_2 Nov 21, 2008
    This set takes several minutes to warm up and then it flickers for several minutes. The picture eventually shows up but it starts flickering again and we have to turn it off and back on. Please help. Is it worth fixing
RETURNED SET THANKS
Posted on Jul 06, 2008
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
My rca tv model num. d52w14 keeps shutting off and has trouble turning back on
Put a piece of black tape over the left side of the remote control light in the front of the tv set. I did this with my set because I had severe problems with shutting off this fixed my problem.
Sep 28, 2009 | RCA Televison & Video
TV will not turn on
Replace the CP150 CP120 and CP114 capacitors. You can get the repair kit for your RCA at the following link www.tvrepairworld.com The kit contains the capacitors and CD with detailed instructions
Sep 05, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w14 power light comes on briefly then goes
1. the supply had a fault and needs to be repaired or replaced.
2. www.partstore.com might have your supply or you can pre order it from them.
Good luck hope this inforamtion does help when it doubt get a service guy to come out.
thanks and please rate.
Aug 22, 2009 | RCA HD52W58 52" TV
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model D52W14. tv wo'nt turn on.
i think your flyback may be bad and wont allow the tv to come on anymore....better to replace than repair
Dec 28, 2008 | Televison & Video
Rca will not turn on
16v 2200uf capacitor on the 6v power supply bad top of capacitor usually domed
Aug 17, 2008 | RCA HD52W58 52" TV
RCA D52W14
That model is famous for bad flybacks that shut the set down and there is no warning they just quit working. If you need further info please let me know.
May 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca on then off by its self
http://www.techlore.com/forum/thread/20588/RCA-D52W14--HELP-/
sounds like maybe a problem with the power supply (flyback) which is what im reading is a common problem with this model RCA.
here is a excerpt from a forum posting :
10756-48X on the label on the flyback,location number LL08(the thing with the red wires)That would be P/N 259296
If the label shows LL08 to be 10799-63X then the P/N would be 265409.Both about $40.00 from Vance Baldwin or Union Electronics.Use the right one or you will have further problems.This should complete all repairs.
sounds like you need to figure out which one you need and order it and will require some soldering. If you arent comfortable with soldering then you might save some money by ordering the right part and taking it to a repair shop to have them install it.
Hope this helps. good luck.
Jan 22, 2008 | Televison & Video
RCA D52W135D 52 in. TV/DVD Combo Logo
144 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
