Question about Pioneer SD-643HD5 64" Rear Projection Television
Will not power at all.
We had a storm a week ago and the tv was on a surge protector and sat. and dvd and phone was on same strip. the tv would not power stand but or main. i took cover off back no smell of smoke nothing looks burnt nor does the lockets on strip or wall. is there any hope of fixing or solving this?
  • tinyshaun Jul 06, 2008
    checked them and both had power.
    Sergeant:
    Champion:
  • 310 Answers
Check the power is coming to tv.....
Posted on Jul 05, 2008
  • khader ibrahim Jul 05, 2008
    First Check the power is coming to the socket....
    If its ok means then check the power section in ur tv.
  • khader ibrahim Jul 06, 2008
    Did u well known in electronic means continuity is their in power section...If not means pls go to the Electronic engineer...
4red and 8 yellow code flash
I cannot post URLs here. Please try go googling this: "WD-73738 error codes"
The first result looks promising
Aug 18, 2014 | Mitsubishi WD-73738 73 inch DLP 1080p...
Magnavox MDR537H/F7 no power
Some surge protectors cut off all power, when they reach the surge protection limit in joules. Power strips have reset buttons to restore power. Try plugging it directly into the electrical wall socket. If it works, then purchase a new surge protector. The DVD recorder may have a internal fuse that has burned open.
Jun 03, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
My sharp LC-46SV50U wont turn on
get the service manual and then open it up and do a voltage check on the 5v standby.
if it's not showing anything, then you need to hunt down if it's the ic, cap, or diode or a combination thereof.
Nov 24, 2013 | Sharp LC46SV50U - Lc46sv50u 46in Lcd Ccfl...
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
I have a AT@T Model No. E5908, 5.8GHz Corded/Cordless Telephone/Answering System that has always worked perfectly until a bad lightning storm hit a couple of days ago which caused the power to go off. The...
I hate to be the bearer of bad news, but there is no reset on the phone system, and it's a near certainty that a power surge during the storm "fried" the sensitive circuitry in your phone. The same thing happened to me a couple of years ago and I ended up replacing my phone system. A corded phone in the house at the same time lost its ringer during our storm. To this day it still works fine, but will not ring. While you cannot save your present equipment, it's possible to protect your replacement by installing a phone line surge protector (available at just about any store that sells phones or computers) and a whole house surge protector that you install at the main outside breaker box (you'll need to search the web for that one. Look for a SYCOM surge protector).
Mar 30, 2011 | AT&T Lands Phones
I had a power outage a couple nights ago, which has caused my television to not turn on. It is a Toshiba model CZ27T31, which was off & plugged into a surge protector at the time the storm knocked the...
Please check if your surge protector is working properly now. There is possibility that the surge protector is blown off due to high voltage surge. Check if your surge protector has a reset switch which some of the surge protectors have. If the problem still persists then you have to call the technician to replace the safety fuse which is inside the TV. The cost will not be much. I will personally recommend that you change your TV as it has outlived its life being 10 yrs old.
Aug 10, 2010 | Toshiba Televison & Video
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
Blinking standby light, dead dvd player
Hello illeanaceres,
I'm sorry to hear about the bad news, I had something similar happen to me around a month ago.
Honestly there is not much you can do if it is damaged due to a power surge. Resetting it would be the normal procedure.
Surge protectors only protect equipment up to a certain amount of joules. Basically if the lightning is powerful enough it can damage electronics with that initial surge. You should replace your surge protectors every few years if it is 2-3 years old then it may not be as effective.
Post back if you have anymore questions or comments. Thank you for choosing Fixya!
Jul 13, 2009 | GPX D1816 DVD Player
42" westinghouse flat screen wont turn on
Some surge protectors fail just when most needed.
Jun 19, 2017 | Westinghouse TX-52F480S 52 in. LCD TV
Pioneer SD-643HD5 64" Rear Projection Television Logo
53 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
