Question about Car Audio & Video
Need panasonic radio DP300 plug wiring - Car Audio & Video
Need stereo color wiring diagram for 1995 Chevy Astro Van. Old radio stolen.
Easiest to replace would be the factory Delco AM/FM CD...plug in to existing terminals. If wires cut, you should include the plug in terminals with the replacement radio...Local Pic-A-Part is my go to salvage yard radio $25-$75...Walmart also sells radio wire install kits...$14.95? Hope this helps.
Apr 21, 2016 | 1995 Chevrolet Astro
I need a wiring diagram for a Panasonic CQ-VD7001U car stereo. Can someone please help.
You need the wiring harness that came with the stereo in the box it was in.
Next you'll need an aftermarket radio harness which you can find here just plug in your car info.
Fit My Car aftermarket car guide
Feb 08, 2012 | Panasonic Car Audio & Video
I need to get a wireing harness for Panasonic CQ VD7001U
Are you missing the wiring harness that plugs directly into the radio? If so, then you will have to contact a Panasonic dealer or Panasonic's website directly. If you are looking for a wiring harness to install into your vehicle, you can find them at www.crutchfield.com
Aug 28, 2011 | Car Audio & Video
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
Removing radio from saturn to install stero
The plastic surround cosmetic piece which goes around the radio and climmate controls just snaps out to the rear with some gentle pulling. There will be then exposed two small bolts on either side of the radio. Unscrew them and the radio pulls out, the antenna wire and plug for the wiring harness will have to be disconnected. Note you will have to have an adapter for your panasonic to plug it into the GM wiring socket. If you stroll over to ebay motors you can find these adapters and find many replacements in case you break the cosmetic piece when you remove it.
Oct 04, 2009 | 1994 Saturn Sl
Wanted Wiring diagram panasonic car radio tape player p114
if the panasonic radio is a factory model, check with a GOOD car audio shop. they can get you the factory wiring harness to plug in, along with the diagram. if the panasonic is a replacement, like a jensen or kenwood, check out CSK Auto or AutoZone for a factory harness adapter. it makes life so much easier...
Feb 01, 2009 | Panasonic Car Audio & Video
Make a ipod work on a panasonic cq-vd6505u
Ensure you have this cable (Panasonic Car Audio CA-DC300U iPod Connection Cable for Panasonic Car Stereos) or if you are wanting to put a Ipod with video you will need the CA-VDC300U. The cable plugs directly into the back of the radio or to the CYEM-100U expansion module. Once the cable is plugged in and the radio is installed (if you hooked the cable up to the back of the radio) turn your car on so the radio works, when the radio comes on hit your source button that allows you to switch between the DVD player and the radio. You should now see a button that shows your Ipod. This will allow you to control your Ipod through the radio and the cable will ensure you Ipod is always charged. This should work if you have the correct cable...I actually just hooked up my Ipod to the exact same radio today using the CA-VDC300U and the expansion module.
Oct 28, 2008 | Panasonic CQ-VD6503U Car DVD Player
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
