Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
WEGA KDF-55WF655 6 blinks
I have the exact same issue w/ exact same TV...
Did you get a solution?
  • David Gillis
    David Gillis Jul 09, 2008
    I have a 3 yr old Sony 55"Grand Wega. Sometimes when I turn it on it will work fine.Most times recently the screen goes dark or is very dark with red lines throughout the screen- sound is still on. I'll shut it off for a moment or two then when turned back on it may or maynot stay on- mostly it reverts back to the dark screen with hard to see red lines.After an hour or so doing this it will stay on. The only blinking light is green -sometimes 4 sometimes 16 times -once tv is working properly the green light is steady.
  • Whyte23
    Whyte23 May 11, 2010
    Good Day...Good People,
    I having the exact same problem the picture turns off and on by itself....the power button blinks five or six times in "Red"....then powers back on by itself.
    Last month the 24th of June,2008....I just replaced the lamp that was manufactured to fit the Sony KF-50WE610 projection TV. Installation went well. No problems...until this the picture turns off by itself issue started about two weeks ago.
    Thank you in advance for any assistance,
    Whyte23
Yes, it was the themal fuse on my set. You can pull the front lamp cover off and see it clipped in on the right side. It is looks like a square shaped object with two wires going into it. The fuse is 1/4 inch or smaller and is in itself a small wire harness. You must remove the lower back cabinet to unplug it from the other harness. Hope this helps.
Posted on Jul 12, 2008
    Scholar:
  • 137 Answers
Hello malenoj,
To make another long story short....you have a bad thermal fuse. This fuse can be found near or around the lamp housing. Part # 1-910-023-93 Average cost $10
Best regards
circuitcity
Posted on Jul 08, 2008
2 Suggested Answers
  • 87 Answers
SOURCE: sony wega kdf-50e2000 standdby light blinks 8 times
8 BLINKS B -10.5 IS OVER VOLTAGE (B-BOARD) If your a novice call Sony or a Sony authorized service center.
Posted on Apr 14, 2009
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
Jan 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have Sony TV model KDF-42WE655 which stopped working. No display and when powered on, the green light comes on and blinks approx 50 times and turn red (blinking red). How and what do I need to buy to fix...
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
Dec 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF 50WE655
3 times blink means Lamp Cover is not placed back that was removed while replacing lamp, make sure lamp cover is fixed securely in its position.
Thanks.
Sep 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Overheat issue on kdf-50we655 sony tv
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
this link tells about the blinking and how it's an self-diagnostic system that the tvs are programmed with. the number of blinks indicates the problem.
Jul 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv will shut off and red light will flash 3 times
If its Sony KDF-42WE655 TV that goes to standby and LED blinks 3 times then check Lamp Door that seems not fixed properly.
That happens when lamp replaced in TV.
If its different model number TV, let me know exact model number.
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony wega kdf-50e2000 standdby light blinks 8 times
Mar 25, 2009 | Sony KDF-50E2000 50" HDTV
Sony Grand WEGA KDF-60XS955
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
Oct 08, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
241 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
