Question about Lexmark X1270 All-In-One InkJet Printer
Printing I have just refilled my cartriges, I have cleaned the nozzles etc and done everything on the lexmark trouble shooting thingy. My printer makes a sound as if its printing and the cartriges move from side to side but nothing is coming out exept blank paper. Please help
  • rtatekht Jul 07, 2008
    There is ink in the cartridge but nothing is being printed on the paper.
  • bijanfard Jul 19, 2008
    I have a lexmark too, I installed two cvartridegs needed, Black and the other Colo, But despite both of them to be new only black shows in the print result . it makes sounds like it is moving back and forth but in the result I don't see any of the other colors .I have installed new driver and printer is in a good shape , It was working with no difficulty, only lately this happened . any help ?
    Problem Solver:
Hi, I had the same problem and I simply gave up in the end after trying every bit of advice I was given. I then found out that I wasn't alone in this problem with the Lexmark so I bought a different brand of printer.
Posted on Jul 07, 2008
    Problem Solver:
  • 16 Answers
Make sure that you have taken off the special tape that is put on the end of the cartriges so the ink can be used, you may have just forgotten to take it off.
Posted on Jul 05, 2008
    Scholar:
  • 135 Answers
Sir i think the prob is that u havenot inserted the catridge properly..
pl chek over it and everyting will be fine
My Lexmark X1270 printer at one time worked, everything was good, then when I put a new color to black will not print any other color or a black color, print only a little pale, almost do not see anything...
Lexmark products work best with genuine supplies. Lexmark does not recommend the use of refilled, remanufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
You can try to clean your cartridge nozzles using the Lexmark software on your computer. From your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If that does not help, maybe it would be best to replace your supplies with genuine cartridges.
I hope this helps.
Dec 02, 2011 | Lexmark X1270 All-In-One InkJet Printer
I refilled the cartridge but it still willnot print
Please note that Lexmark does not recommend use of a refilled cartridge. Refilling a cartridge can affect print quality and may cause damage to the printer. For best results, use Lexmark supplies.
You may try to re-insert the cartridges and make sure they are seated properly or clean the cartridge nozzles. Manually wipe the cartridge nozzles with a slightly moistened soft cloth to clean it from possible dirt and clogs. Then, reinsert the cartridges in to the printer. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please replace your refilled cartridges with new genuine Lexmark supplies.
Sep 19, 2011 | Lexmark X2600 InkJet Printer
I have had no problem with refilled cartridges up to now for my lexmark printer. After having the computer cleaned and updated etc. a new message appears on the screen when I want to print. It says the...
Lexmark does not recommend the use of refilled/remanufactured cartridges. They tend to degrade print quality and cartridge performance since refillers don't have access to Lexmark ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
Note that when a cartridge is refilled it can no longer register its ink level.
Aug 23, 2011 | Lexmark X2500 All-In-One Printer
My printer dont print right it skips and i just put a new refill in
It could be due to the refilled cartridge you are inserting in the printer. Refilled cartridges tend to degrade in print quality and cartridge performance.
You can try to clean the cartridge nozzles. On the printer operator panel, on Copy mode, press the Menu button > Tools > Maintenance > Clean Cartridges. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the print quality has improved.
If that doesn't help, I would suggest you replace your refilled cartridges with new genuine Lexmark cartridges.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
I had refilled my canon 831 color cartrige but it is not working and it is also blocked non of the color is printed in pattern check. how can i resolve cartrige blocking problem????????//
Open the printer and remove the catridge
Use a tissue paper and clean the nozzle where the ink comes out from
After you have cleaned the nozzle, press the catridge on the tissue and see if the color stains the tissue
If it does, you put the catridge back into the printer and then try to print.
Jul 06, 2011 | Computers & Internet
My printer is brand new as are my ink cartriges. My printer prints blue lines over all documents
Try to manually clean the nozzles on the cartridges. Refer to this article in the Lexmark website on How to Clean the Print Cartridge Nozzles and Contacts Manually. This may improve the print quality on your printer. If problem continues, please contact Lexmark technical support for additional assistance. Thanks.
Feb 21, 2011 | Lexmark X2670 All-In-One Printer
Refilled black ink cartrige and i can't get it to print at all. done more deep cleans than i want to remember, still will not print. done nozzle clean also. i have refilled this cartrige several times...
You may need a newer cartridge
See if the printhead has any abnomal markings.
You can compare it with the color printhead.
If the printhead is good, see if the ink is flowing through the printhead.
Fill the ink cartridge to maximum
Squeeze the sides of the ink cartridge, ink should flow out.
If ink is flowing out, remove any excessive ink with a paper towel.
Install ink cartridges, do NOT do any cleaning cycle.
Since your black cartridge is full, cleaning may cause it not to print.
Do some black copy operations.
Jan 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Lexmark 1240 black ink prints in streaks.
Take the cartridges out, then unplug the machine so the cartridge holder stays in the middle. Take a bunch of wet q-tips and clean all around where the ink would come out. Check rollers and anywhere the ink could have dripped. Double check the maint. station, sometimes there is a wiper thingy that jumps up to wipe the inks.
Apr 29, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
Incorrect ink level reading
kiwipom, While ink cartridges look like plastic cups that only hold ink...they are not. The information the printer needs to think it has a "NEW" set of ink cartridges is on the cartridge itself. You must fakeout the printer to believe you are inserting "new lexmark" inks. Printer companies make money from the repeated sale of the ink, not the printer itself. I had an old epson that I would refill I would then have to place pieces of tape on the cartridge turn the printer on, remove the cartridge move the tape to another side of the cartridge turn on again etc. Anyway lexmark may need the same. When the new original cartridges show try them first to get the printer "thinking" correctly. Let me know what happens. Good Luck, Tim
Feb 27, 2007 | Lexmark X7350 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
